Thread: need help with brake situation
03-20-2007 #1
New to Pro-Touring
- Jan 2006
- 3
Car is an 81 pontiac formula with the ws6 brakes, 11" rotors front and rear. Stock calipers in front, but I used 84 olds cutlass front calipers in the rear, same bore diameter (just no e. brake) Bore for the front is 2 15/16" and rear is 2 1/2". Removed booster and added 68 corvette manual disc/disc m/c (1" bore) Pedal pushrod was moved up from stock, almost level with m/c. Still has the stock prop. valve. Line loc installed. System bled, no air. Car is a drag car, skinny tires in front and tall, wide tires in rear.
Now, the problems. Pedal seems soft, but will get firmer when you pump it. Doesn't seem like it wants to stop. Will not lock up no matter how hard you push the pedal. Front brakes will not hold enough to make the line loc effective, car will overpower the brakes and roll the front tires, not just push them along (locked)
Through reading many posts on brakes on this site, I have a few thoughts.
1. My master cylinder is not matched to my calipers? Just checked and there is a manual m/c for my year car, factory. Don't know why I didn't see it earlier.
2. My prop valve is wrong and need to remove it and get an adjustable one?
3. My pedal ratio is wrong and I need to go back to the original hole for the rod?
4. Do I need a residual valve for the rear brakes? If so, what size?
Am I on the right track with this stuff? Anything else I should look into? I trust you guys here because you are building high dollar cars that have to perform on the track. Thanks, Gregg
