    Results 1 to 9 of 9
      Kettering, OH
      Screwed myself - please help with Plan B
      I am at the point where I'm going back and redoing things that were done during my misguided attempt at a correct restoration. I just finished the Hydraboost conversion and am ready to tackle front and rear discs. I was planning on C5 or the C4/C5 hybrid in front, but the step in the hoop on my 17" Boyd 2-tones will not allow it - not even close. There goes my ultimate hope of ATS spindles etc...
      Plan B: I am thinking the 4th gen F-body discs up front with C5 calipers might be the way to go now. Unfortunately, I already have disc spindles and don't know of anyone that makes a bracket. What do you all think???
      I am also planning on the 4th gen brakes in the rear and already have the parts off a wrecked '98. Because this is a Pontiac non c-clip rear I am stuck with making my own brackets. I'm also at loss to find anyone that can definitively say how to do the parking brakes. Any advice?
      I figure I can go with LS rotors and C5 calipers all around. This will be a street driven car with some aggressive back road driving.
      Aug 2003
      What is the inside diameter of your wheel? Do you know what you mounting pad to spoke clearance is?
      CT
      California
      Maybe I'm misunderstanding, but couldn't you just run a spacer/adapter? Seems like that would be the easiest solution.
      Matt
      Kettering, OH
      Frank: I would have to remeasure, but IIRC it's 15.5" because of the step in the hoop. The step is there because I bought the fat lip/smooth lip version of the wheel.
      I have been to T-C and Kore 3 websites, have downloaded and calibrated the templates for C5 and C4/C5 hybrid packages and even with the maximum spacer I would dare run, I need about another 3/8 to 1/2" in the hoop ID. In otherwords, I would have to grind about 1/4" off the top of the calipers and that is not something I want to do.
      If I run the 4th gen rotor, I can gain about 3/8" additional clearance to the hoop. The problem is all in the ID because there is plenty of room between the hub face and back of the spokes.
      I have also been to David Pozzi's site and confirmed my problems, but did not find any new info.
      Kettering, OH
      Here are a couple of pictures showing the problem. The hoop has a step on the back side of the spokes that cuts into the available ID. In the second picture, the ID is actually 15.5" although the picture angle shows it less. By the templates, I really need another .5" of ID to run the C5 or a little less than .5" to run the C4/C5 hybrid brakes.
      The 4th gen f-body rotor will buy me 0.75"
      Does anyone have drawings for the LS1/4th gen front disc conversion bracket? I would like to get a set made for disc spindles.
      Aug 2003
      Are you commited to this brake set up? You do have a clearance issue with that set up. You could do a 12.2" 4 piston front and rear Wilwood set up and have no clearance issues and cure your e brake problem with a included internal e brake. You can do this entire set up with both F and R kits, E brake cables, Master Cylinder, Braided front and rear hoses, and even Hi Temp Dot 4 fluid for $1550. I do not know how cheap the hybrid set up was going to run, but it cannot be much less.
      CT
      I think Frank's got the answer.
      Wish I could be more help.
      You can sell the parts you have to soften the hit.
      I might be interested in the rear brakes.
      Send me a pick and what you want for them.
      Kettering, OH
      Maybe I should be committed, but not to these brakes. I would like to go with a factory disc/caliper setup so I can have more peace of mind on the road. The Wilwood setup looks very tempting though.
