Results 1 to 11 of 11
Any install tips for Stage 2 kit from SC&C?
I just ordered the Stage 2 kit from SC&C for my 87 Regal. The kit comes with adjustable upper control arms with installed taller ball joints and taller ball joints for my stock lower control arms. I will also replace the lower control arm bushings with the delalum bushings from Global West. My car is a 48K mile car that has had an easy life, so rusty/frozen bolts should not present an issue. As a military member, one of my fringe benefits is having access to what we refer to as an "auto hobby shop" which is basically a do it yourself garage with numerous tools/lifts, to include a press to press ball joints/bushings in. When I am doing this, I will also be installing my Baer brakes I had on another G-body.
As far as front end suspension work I have accomplished in the past, it is pretty much limited to spring/shock/ball joint (on car replacement) and removing spindles to install Baer brakes. In other words, I have never pulled off control arms.
So, for all you back yard mechanic types, what tips can you offer me? How long do you think this should take an average shade tree mechanic?
Marcus at SC&C said it will be two-three weeks before I get my parts, so I plan on using that time to liberally apply penetrant to all the nuts/bots that will be wrenched on.
I appreciate any responses anyone cares to share.
Rob
