      Nov 2004
      The original home of Nickey Chevrolet
      Cold solid lifter lash
      I am ready to fire a small block chevy with a solid roller camshaft.
      The maufacturer (Ultradyne) is no longer in business. I have a cam spec card that says "hot" valve lash is .026. The engine was sitting for some time and all the rockers were loosend for storage. What would be a safe lash to get this engine going for initial fire up. Thanks,bc
      Delaware, OH
      This chart has always worked for me. Zero cam break-in problem so far.
      http://www.cranecams.com/?show=faq&id=4
      Aug 2001
      Connecticut
      That chart is pretty on- I always figured .004-005" tight cold for aluminum heads; but the .012 tight for aluminum block is what I do-- if you've ever tried to set valves hot with an aluminum block it's tough-- moves so fast as it cools off quickly.
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Nov 2004
      Quote Originally Posted by 68sixspeed
      Yep. Lash .005" tighter than spec when cold with iron block and aluminum heads.
      Sep 2001
      Accord, NY
      That worked so well for me that I went with cold lash adjustments which was a bit easier. I always wondered about 'hot' settings as you went through the valves and the engine is cooling down.
      68 camaro - SOLD
      May 2004
      Dallas, TX
      I used that same chart when cold lashing the solid roller in my stang...and when I hot lased they were all within a thou or two of the hot spec.
