Thread: Input needed on caliper mounting
03-15-2007 #1
I'm mocking up my rear brakes and found out with the quadra link and baer brakes I can only install the caliper in one position where it will not run into suspension or wheel well clearance problems. Here is a couple of pics.
1. Does caliper position make a difference on braking performance?
2. The stainless brake line is not very flexable and I'm concerned about problems with the floating caliper binding due to the brake line. I dont have alot of room to work with, How much play should I have with the line hooked up? Would a longer line with a good sized loop be in order?
Matt
Matt
