    Results 1 to 10 of 10
    Thread: "El.plating"
      Oct 2006
      Norway
      "El.plating"
      Will plating spindels damage the matrial in my spindels. Know that hot zink/ galvanizing makes the material softer...Don't think plating will but it's better to ask...
      Thank's
      Olav
      little falls minnesota
      Ive been told by our plater that electos nickle plating will embrittle the parent material. I don't know what effect it would have on spindle material, but I was going to have him plate a couple of guns for me and he advised against it.
      I'll ask him next time I see him.
      Doug
      Southern Indiana
      You need to talk to chrome shops as the best shops will bake the parts to release the hydrogen from the metal that akes it brittle.
      Another idea would be one of the "chrome" like powder coatings or one of the Jet Hot type coatings.
      The big problem with that plater is that he isnt a registered firearms plater(most of them have to have certification to legally nickel plate a gun so as to certifiy it as properly degased and this comes from an armourer friend of mine) According to Phil there is less than a dozen authorized and certified platers that can truly do the job properly as the process isnt like the nickle plating before chroming.
      The big problem is that the parts need to be supported while baking or the parts will get "tweaked" or basicly they relax to the wrong dimensions.
      Ask a lot of questions and make sure they have proper support fixrtures and do bake the parts.
      But iwould not use them in anything other than plain driving or show cars, never autocross or race them. Period.
      Good luck
      Lee
      Your right about the gun thing, I was just trying to save a few low powered ones from the elements without having to have them hot blued.(which seems no one but the factories will do anymore.)
      He did electros nickel some of my suspension pieces and that is what I have heard is about the best corrosion protection you can get if you don't disturb the plating. Mark Stielow(sp.) did one of his arcticles on one of his Camaros where I believe he elect. nickeled a bunch of the suspension pieces. Might be able to get some more info from there.
      Doug
      Oct 2006
      Norway
      Talked to the shop that does the plating. They said it don't do anything to the structure of the steel. This is a "cold" process.
      Olav
      Oct 2002
      Houston,TX
      Quote Originally Posted by pav8427
      Doug
      Does anyone remember what car this was done to?
      Or does anyone has some pics of nickel plated parts? I have seen some pics from google... Just not any around here.
      James J.
      Apr 2007
      Clarksville, TN
      I'm pretty sure it was the Mule. He did a series on it in Popular Hot Rod. They were "hardcoating" aluminum I think. It's been awhile since I've seen the article. It did change the sizes of everything on an extremely small scale but it could be a problem.
      Matt
      Central CA USA
      Most of the Vintage race "formula" type cars and Can Am cars have their suspension links and wishbones Electroless Nickel plated. It's a low temperature process that has very little Hydrogen Embrittlement. The chemicals themselves generate a plating charge, no outside source is needed.
      Here is some info on it: http://www.corrosion-doctors.org/Met...lectroless.htm
      Pull a Nickel out of your pocket, that's how it looks. The finish is dependent on how the part was treated prior to plating. I've seen parts glass beaded that looked satin, parts that were polished came out almost looking very shiny, almost like Chrome, except the Nickel is not quite as bright as Chrome.
      David
      In the photo below, the roll bar laying back and the antiroll bar appear to be chrome, the half shafts and suspension links, plus tail hanger with tail lights attached are electroless nickel.
      Oregon
      David pretty much nailed it.
      Electroless nickel is one process, electro-plating such as zinc chromate for steel and anodizing for aluminum are completely different processes. Most industrial steel fasteners have either zinc or cadium electro-plating (OE automotive uses a lot of mechanical zinc), and the higher the tensile strength of the material, the greater the risk of hydrogen embrittlement. Typically anything with a yield strength under 100ksi isn't going to be overly sensitive to it, like Grade 5 or 8.8 bolts. The Grade 8/9, 10.9/12.9 hardware must be baked after plating to release hydrogen trapped in the outer surface of the material or else they tend to fail.
      In a spindle application, the only thing to worry about would be the spindle pin. I haven't done a hardness test on a spindle pin, but they don't seem that hard to me based on the nicks and scratches I have seen in them...I'm betting that they're designed more for toughness and fatigue life than ultimate strength.
      If you were to go with electroless nickel instead, it is a build-up process and the thickness of the nickel will define it's corrosion resistance and appearance to a certain extent. My plater uses .0002" coating as it's standard and anything over .0004" starts to cost more because of the additional nickel depletion of the tank nickel solution. Bearing fits may require that you machine/grind the pin to be undersize before plating. Electroless nickel can be heat treated up into the mid-50's Rockwell C scale to gain hardness, abrasion resistance, etc but I don't think that gains you anything here. In fact, large differences in hardnesses between the plating and substrate can lead to surface cracks propogating into the base material...this is why you shouldn't typically chrome suspension parts.
      What's your goal in plating your spindles? Is it for corrosion? Looks?
      Tobin
      KORE3
      It's what I does.
      Degassing the parts after an electro plating process is done only to 400-420* same as powder coating. I dont see how a part could tweak at only 400*
      There are also 2 forms of Electroless Nickel that Im aware of. Food grade and decrotive. Food grade is a duller brown tint and decrotive is the near chrome look.
