      Jun 2006
      Katy,TX
      2004-06 GTO calipers
      How so these calipers/basket(brackets) compare to the othe rGM PBR types-size, pistons? I know the 05-05 used a different caliper bracket for larger rotors.
      Phoenix AZ
      I just bolted a set of the calipers to my 70 gto using the same C5 saddles etc, just bolted on the GTO calipers straight across. I have the GTO saddles and the bolt holes are located different then the C5 one. Don't know if that helps or not but hope it does.
      So the calipers interchange?
      Phoenix AZ
      Calipers, yes
      Kitchener
      is there anyway you could post any pics?
      Jun 2006
      Katy,TX
      So could brackets using the Corvette calipers be redrilled for the GTO brackets spacing?
