Results 1 to 12 of 12
03-05-2007 #1
difference in 64 and 65 GTO frames
anyone know the difference made from 64 to 65 to stiffen the frame? I read in a book of the history of the gto that there was some stiffeneing done but didnt mention what was done.
03-05-2007 #2
New to Pro-Touring
- Feb 2007
- 58
I don't know, but my father has a 65 I can look at. If you take some pictures of your 64 I could look for differences.
03-05-2007 #3
- Dec 2006
- Los Angeles
- 334
They had experienced cracking of the rear crossmember in the 4 speed cars, so they added the stamped re-inforcement braces after the start of the '65 model year.
I believe there was also a retrofit for the cars that didn't get them before the tsb, but I am only going off of memory from about 8 years ago when I read about it.
From what I remember reading, they only had them on manual trans cars, but I added them to mine anyways, though I don't know it will be enough once I get some traction, even with a slush box.
03-06-2007 #4oh cool thanks for the info!
I was thinking of reinforcing all the cross members. my welder could only handle it if I used the flux core wire but I don't know if its good to use flux wire for stuff like this.
03-06-2007 #5
Banned
- Feb 2007
- East Freetown, MA
- 513
No difference between flux core and non flux in this instance. The flux will probably penetrate a little bit better (given the same heat settings). But, there is more mess to clean up afterwards...
03-06-2007 #6
- Dec 2006
- Wisconsin
- 67
In my Pontiac GTO Restoration Guide.
They note :
Both the 1964 and the 1965 used a perimeter, swept-hip-design frame. The was one major difference between the frames used for the two years: The 1964 frame used a riveted rear cross-member: the cross-member in 1965 was welded. Convertible frames were boxed, and carried the same part number as the optional 1965 heavy-duty frame. All frames were painted gloss black.
That was word for word... hope it helpsKal
66 GTO
03-06-2007 #7
