      San Bernardino, CA
      May 2007 CHP: LS2 w/ tremec
      anyone see the article in the May 2007 issue of CHP where they use a mcleod bell with an adaptor to bolt a tremec to the new LS based 364/440 engine? so if they got it to work, why cant you use the same hardware for a muncie? input shaft length is the same right?
      Yes, that's exactly right. You can bolt the Muncie up the same way.
      jp
      ​John Parsons
      San Bernardino, CA
      bringing this post back from the dead...
      i am the exact opposite of most of you guys here. i want to build a 6.0 motor with L92 heads and a carb intake so bad! i plan to use hooker mounts and long tubes. my firewall is smooth and i have a hydroboost set up. plenty of room.
      i currently have a 69 camaro with a built gen I engine and M22 muncie. i was looking in the may 2007 issue of chevy high performance in the article "four plus one" they install an TKO-600 behind a LS2.
      they use a hydraulic T/O bearing kit from classic chevy 5 speeds. from what i understand that T/O bearing will fit the bearing retainer on a muncie. my concern in the flywheel and clutch.
      can you bolt an older 11" clutch to a LS flywheel? McLeod makes modular bellhousing just for matting a muncie to an LS motor.
      if that works then maybe just maybe it would be possible to make a bracket that bolts to the bell for the stock pivot ball so i can retain a mechanical clutch (that would be sweet) without getting in the way of headers.
