      Oct 2006
      LS1 caliper question
      Ok here is my question.
      I have a 2000 camaro Z28 and I was wondering if I could swap the brakes from that over to my 1967 camaro.
      I keep reading about using the C5 calipers but I was wondering if i could use the ones off of my camaro. Are they different? And lastly if I can what ALL will I need to make the swap. I am willing to take anything of the 2000 to make it work
      Marshall , MO
      you need everything from the backing plate out. If your shocks are staggered you may have to re drill one of the backing plates to clear the shocks. If you search you will find lots of info. The C5 and camaro rear calipers are interchangeable.
      Brad Shepard
      69 Malibu
      Marshall, MO
      Kettering, OH
      BRP Hotrods has everything you need for the fronts and backs except parking brake cable brackets.
      Oct 2006
      Thanks i will give them a call
      For the rear do you have to relocate the shocks?
