    Results 1 to 11 of 11
      Jan 2007
      67 full disk brake conversion
      is it cheaper to buy a kit from a aftermarket brake site.
      Or is there a cheaper method using a newer car (corvette)
      anything anyone can provide will be of help. Pic would be great.
      thanks again.
      Feb 2006
      SoCal
      ***Under Construction***
      Build Update Link:
      Lake Tillery NC
      I just installed a touring classics hybrid front kit and a kore 3 kit on the back of my 68 Camaro. I bought the rear as a kit, and built the front from different sources. By the time you chase all the parts down it would be just as cheap to buy a kit.
      Mike
      Michael Tucker
      1968 Camaro
      Apr 2002
      North Central Texas
      Quote Originally Posted by Tucks69
      Mike
      I agree with Mike. I did the chasing down of parts myself and I should have just saved the hassle and bought a kit.
      There are many different brake vendors here with alot of different kits to look at and see what you want.
      Good Luck
      Shannon
      Modo Innovations
      940-391-9002
      May 2002
      Northern California
      you just gotta know where to look. http://www.engineeredvelocity.com/
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Fillmore, California
      If you can live with 2" drop spindles I have everything you would need. It all has about 1000 miles one it. I am running them on my 73 Nova right now. They have 11 inch rotors and 4 piston calipers from a 1LE Camaro. 400.00 plus shipping for everything.
      Jake
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by Gaslight
      Jake
      1LE are 12" rotors, no?
      Scott from NJ.
      Vent Windows Forever! ...
      My bad you're right. Brain fart!
      Jake
      Feb 2007
      Maybe interested. Would I have to use a different master cylinder than the manual one from the drums on it now?
      Houston, Tx
      Here is what I did...
      Front - total cost ~$1100
      ATS Spindles
      c5 corvette rotors, calipers and abutements
      Rear - Total cost ~$500
      Brp Bracket - $40
      Brp Shock Relocation Kit - $150
      Ls1 setup off of ebay - $150
      Rotors, pads - $150
      For about the cost of CPP setup I netted a set of ATS spindles and I have a parking break. I now need to get a 69 stingray manual master (~$25) and all new lines (~$250) and I will be completely done for about 2K total and have awesome stopping power.
      Houston, Tx
      Note -
      because you have a 67 camaro you don't have to get the shock relocation kit which will save you another $150
