    Page 1 of 3 1 2 3 LastLast
    Results 1 to 20 of 47
      Possible Budget LSX Accessory Drive Systems (GM P/Ns)
      I know many people like myself are looking for options for accessory drive systems in LSX powered vehicles and cannot really budget $2200-$3000 for a drive system.
      I may have found an alternative, but I haven't found any real good pictures of the system. GM has two versions on an accessory drive system for LSXs. One for with AC and the other without. They the following:
      GM PART # 19155067
      ENGINE ACCESSORY DRIVE KIT - GEN 3 & 4
      WITHOUT A/C
      GM PART # 19155066
      DESCRIPTION: ENGINE ACCESSORY DRIVE KIT - GEN 3 & 4
      WITH A/C
      GM Parts Direct lists the price for them as $701.69. I can't find a good parts list description of what the kits contain or a good picture of them. Anyone have any more information about them?
      The system was used in the Reggie Jackson Camaro.
      Jul 2003
      Anaheim Hills, CA
      My f-body drive system was dirt cheap.. like $200.. lol
      Would like to see shots of this one though..
      1968 Track Rat Camaro:
      Feb 2007
      Dave, are the set ups you are refering to serpentine style?
      As far as I can tell, yes the set-ups are serpentine style.
      I am looking at using one of the kits as I am likely just going to buy a new short-block (instead of a complete motor) and I will be needing accessories.
      Dave
      Oct 2005
      Ferndale, WA
      Quote Originally Posted by Dave95Z28
      Dave
      I'm not for sure on this, put when I went to gm and asked if they have shortblocks for any LS2's or 6.0 LQ4, I was told that they only offer them in longblock form. It sucks, but the parts man said that theey don't really offewr any of the new engines in shortblock setup. But if you can find one or find out the chevy does offer them, please let me know. Good luck!
      72 Chevelle Done!
      67' Hell Camino- Under the knife
      Some day: Porsche GT3/ C6R inspired 69
      steve will the camaro drive work on a 69 stock sub .will the alt clear with lets say ats mounts?
      Springfield, Mo.
      I have the cheaper version of ATS mounts with my stock subframe and my alternator (for a 00 camaro) didnt fit initally. It had a black cover on the back that i had to take off, trim the bottom and reinstall.
      1967 Camaro - Done!
      1968 Camaro - Underway
      thanks ta that is with the camaro drive right i really want the alt down low to clean up under the hood
      L.A.
      I built one Ls with an OEM F-body set up,salvage yard. Wouldn't have touched motor,tranny main shaft pushed out of case.250 with everything. Low alt. was really tight. Second one I bought a Street and Performance (upper pass alt.,low pass A/C,OEM F-body p/s) S&P's site has pics of OEM drives, and damper offsets. My new LS ,I like the satin OEM finishes better,96 & up Corvette,SOME engines may have to swap dampers to match.(Cleveland Pick a Part, Inc.)
      Feb 2007
      East Freetown, MA
      You can use the truck setups (even with a LS1 intake) if you swap two things... ;)
      The truck setup looks like it will put the Alt about 3" through the hood
      Feb 2007
      East Freetown, MA
      All depends on the car I guess....
      Most will be fine.
      Quote Originally Posted by Goatman
      Most will be fine.
      Maybe I'm doing this wrong, The car is a '68 Firebird. I've got an LQ4 from an '02 silverado linked to a 4L60E. There is about 2 1/2 inches from the back of the block to the firewall which keeps me from having to mod the trans tunnel, steering cross link, nor the front cross member. I took the stock trans x-member, wacked the trans mount plate off of the rear of the x-member and glued it to the front of the x-member. The AC hoses are just behind the right front upper control arm cross shaft "Adjusting bolt'. The AC is just above the front cross member (1/4 - 1/2"). With the truck stock intake and alt mount they both would poke through the hood, so I swapped the intake for a LS6 unit that I had sitting on a shielf. I just ordered some of the Hooker LS1 into 1st gen F-body long tube headers today. The high mounted Alt seems to be the current hold-up, but I'm sure that their are more to come. If I could just come up with a lower mount for the alt that doesn't move the PS pump to far from where it is.
      I ordered one of Zoops Serp setups for my customers '69 vette that we are putting a new school LS7 into so I will get to look at that. They do include a new water pump, new alternator, new PS pump and a new AC compressor for $2495, so it isn't a bad deal, but this firebird is a excercise in doing the LSx swap on the down low budget.
      L.A.
      Serpentine systems, short blocks
      I just picked up a new GM Performance Parts catalog with my new engines. cat part #19170580 Has way more stuff for LS Motors. The previous listed drive #19155066 & 19155067 were called out as LS1 &LS6 LS2 & LS7 respectively, both kits coming with a/c, alt,ps,belts brackets, tensioners, and bolts ,as stated no pictures. I'm going to cross check part #'s listed to see if match to my old vette set-up invoices. Part # 's in each kit are different , offsets to dampers I'm sure. They also list quite a few LS long blocks w/out intake but no short only's. Back to bare blocks from there. If your thinking of building out the have the newL92 heads and matching in takes . We can really start to breath 'em out now . get the new cat #19170580. The part #'s are listed,it' on page 235. They also list the new ECM #'s in the engine side bars,LS2 #19166568 comes with PCM,harness, & FBW gas pedal,not programable. LS7 #19166567 with same included parts. I going back tomorrow to see if any of this is actually available yet. (acc'y drives & harness PCM kits) Harnesses listed on 79,89,298 of new cat. 3/17/07 IN CATALOG BUT SERP. DRIVES AND ECMS NOT AVAILABLE UNTIL SUMMER LOL
      Feb 2007
      East Freetown, MA
      C5, once you put on the LS6 intake, the water pump pulley (or the entire pump) and belt tensioner (on upper left hand side of the block when facing it) will have to be changed.
      You need to press off the truck water pump pulley and press on one from a 99+ F-body (98' pulleys are bolt ons). Or just unbolt the truck pump and bolt on the car pump.
      The "other" tensioner you need is sold by Speartec and is designed to work with exactly this type of swap.
      The F-body accessories move the belt down and out from the motor. This mod I have described allows the lower car intake to fit with the truck accessories without the belt hitting the TB. And the belt is still in alignment!
      Hey Chris,
      Thanks for the info. I knew that someone else had walked this path before.
      Would it be possible to post a pic or two?
      Feb 2007
      East Freetown, MA
      Who is Chris?
      Who is Chris?
      Chris Casperson
      Head puss, Performance Years
      Feb 2007
      East Freetown, MA
      Why are you thanking that wanker?
      so you (Goatman) are not Chris?
      I assumed that I was just missing some kind of inside joke and that your name was Chris.
      Sorry if I insulted you.
      1968 Pontiac Firebird, LQ4, 4L60E
      1970 Chevrolet El Camino - on rotiserie
      1996 BMW 325 w/LS6, T56, full Cage, C5 suspension...
      1999 Chevrolet Supercharged C5 coupe SOLD (Tossed out SC and put in 440ci LS7 for new owner)
      2004 Chevrolet Duramax Crew Cab/Dually
      1970 Chevelle SS/402BB/4sp/12 bolt
