      Indiana
      Ignition switch problems!
      Hey guys,
      I need some suggestions asap if possible! The other day I came home from work in my 71 Blazer, turned the key to off and the engine kept running like I didn’t do anything.
      So, being the smart guy that I am, I went to NAPA and bought a new ignition switch. I installed it a few minutes ago, started the engine, let it run for a minute or two and then turned the key to off, and guess what? It kept running! Obviously the ignition switch isn’t the problem. I guess I’m not so smart any more!
      Has anyone had this happen before and if so, what did you do to fix it? This is my daily driver so I need to figure this one out quickly! Thanks.
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Rockford Illinois
      I have heard that this happens when one of the diodes goes bad in the alternator. Get your alternator checked to find out if it is working correctly.
      This is just something I have heard of and have never had the problem myself.
      Feb 2006
      Elk Ridge, Utah
      Yup what Jim said is correct
      that can do it unplug it and retry youll know pretty quick.
      I own a 72 4X4 blazer since 1975 (well passed down to me From Pops)
      69 Camaro
      W/D sub, Wilwood 13" brakes Bozeforged wheels 18X10 & 18X12,
      Lateral dynamics 3 link ( custom setup ) Dana 60
      lsX Twin Turbo, soon to come
      Viper T56 in place (Yay)
      Bought a running driving car so I can enjoy it before Im dead
      LD 3 Link Installed into ^^^^^ (Yay)
      Indiana
      I think I fixed the Blazer. To rule out the alternator, I disconnected all the wires from it, started the engine and then turned the key off with no luck, the engine kept running. So now, with my trusty $5 multi-meter in hand I decided to check voltage since the alternator wasn't the culprit.
      The first place I checked my voltage was at the fuse box and this is where I found the problem. There are a pair of red wires (one large & one small) in a single connector plugged into the spot labeled "Ignition Unfused." With the key off I checked that plug and no voltage. With the key on I checked and there was 12+ volts. I also checked the two red wires in case they were feeding the ignition system but they were dead. Before I plugged those two wires back in, I started the engine and then turned the key off and the engine stopped! I plugged the two wires back in and started the engine again but this time it didn't shut off with the key, so I reached under the dash and pulled those two wires out and the engine shut off. That's interesting. There was another spot on the fuse box that wasn't being used, I checked it with the m-m and it had 12+ volts when the key was on and 0 volts when the key was off. I plugged the two red wires into that spot and everything seems to be working like it's supposed to. Go figure? The two red wires have been in the Ignition Unfused spot since I replaced the harness and now three months later it does this. Weird. In case you're wondering, the stock harness had the two red wires plugged into the Ignition Unfused spot also, which is why I plugged the new harness in there.
      For now it seems to be working, but it still doesn't seem right. I'm going to keep diggin around with the m-m checking voltage. Who knows, maybe I'll find the real problem.
      Thanks for the suggestions.
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Feb 2006
      Elk Ridge, Utah
      Hmm are you powering electric fans off that?
      that fat red wire is the gig lighter that pluggs into the fuse box
      I should know this system like the back of my hand .. Its been a lil bit since I played with one though
      I can allmost tell you what every color wire goes to
      Lemme know what ya find
      69 Camaro
      Indiana
      Yes I have electric fans, but they're powered via relays. Power to switch the relays on/off comes from the fuse box. I've been busy over the weekend but will make it a point to investigate further this week.
      Thanks.
      Herb
