Results 1 to 12 of 12
Thread: Cam warranty
Cam warranty
So here it is…
I just got off the phone with Comp cams warranty department. I installed a complete cam kit including springs, seals, cam, lifters, timing chain etc. Once it was completed I got a severe ticking on #2 exhaust. The warranty department told me that I need to replace the lifters and cam and pull the inner valve springs in order to do a fresh break in. They said that the springs are dual and that there is too much seat pressure for proper break in.
O.K. so my question is this. When you build a new motor do you only put in the outer spring for break in? Do you tell the customer to come back in 500 miles so you can install the inner spring? I know Comp cams knows it’s stuff, but this sounds a bit much.
12-06-2004 #2
Banned
- Aug 2003
- Orlando, FL
- 8,745
Never done it, never had a problem.
12-06-2004 #3
Banned
- Nov 2003
- Maine
- 1,076
break in
harshman, most engine builders have at least a test stand to run a motor on, they break inthe motor on it then add the inner springs, although like frank said some remove springs some do not, the important thing is to keep the rpms up between 2000-2500 for break in , i like to run a bit longer like 25-30 mins, i belive its not the cam thats being broken in its the lifters, they need oil and need to spin inthere bores and at idle they have only splash lubrication, and some will not spin at idle thus needing breaki in, goodluck]
jake
12-06-2004 #4I use lower tension springs when it comes to that-you're only going to 3,000 R's max and with those springs you're okay-then swap out for your regular ones. Only an issue with extreme seat pressure which is needed for excessively high lifts (debatable, though...). -Jabin
12-06-2004 #5
- Aug 2004
- Colorado
- 397
