    Results 1 to 15 of 15
      Dallas TX
      Bone yard Hydra boost??
      Has anyone looked in to adapting the one that started comming on the 05 or 06 GM full size SUV and some trucks.
      Aug 2003
      Bad plan. Those units are built for 6000LB trucks with 10000 GVWRs or more and and become hyper sensitive in 3500LB cars. Paul makes a variety of modification on the HydraTech units to make them work properly in cars. And they are still very sensitive even after he does his magic
      Rolla, MO.
      explain that please.....they are hydraulic, the power steering pump will make more of a difference than anything in the unit itself can.
      gearheads, I'm in the middle of one I'll post up on MR when I get it done
      Matt
      1980 Malibu, off the jackstands.....let's see if a T-56 will last longer than a TH-700R4
      Feb 2006
      SoCal
      http://www.geocities.com/casanoc/
      Go half way down the page.
      John
      ***Under Construction***
      Build Update Link:
      The size of the piston and the hydraulic pressure would be the 2 things that would affect the power, along with the pedal ratio.
      Check out this cutaway. HBs are very simple things really.
      http://members.shaw.ca/pekpress/HydroboostSwap.html
      California City Ca.
      Find a unit from an 84/85 turbo buick, thats what i'm using with 4 wheel disc.
      Northwestern NJ
      Above all else, brakes are too serious of a safety issue to use scrapyard parts for anything other than core value!! Don't cheap out on your brakes Buy new or reconned!
      Tommy
      Tommy Souren
      "The older I get, the faster I was."
      Grandma's 20k mile '80 Malibu Classic, in-progress factory style LS6 454, Legend LGT 700 5 speed, 9" 3.70 posi, Global West suspension, 12"/11" discs.
      Oct 2006
      Norway
      Hydraboost from Chevy diesel van....will this unit work?
      Jun 2006
      Nebraska
      I use a Hydroboost on one of my friends camaro it's from 80's Chevy B body wagon. I use it all the hoses , pump and steering box too thinking of putting a iroc steering box on it.
      Larry
      Cumberland, Maryland
      Didn't/don't a lot of astro vans run hydroboost?
      junkyard hydroboost...
      Years ago I stripped a 78 Mercury Marquis that had factory 4 wheel disc brakes, and it used a "hydroboost" type powerbrake system, with 4 lines coming out of the power steering pump, 2 to the steering box, and 2 to the power brake unit.
      Look for a 77-78 full size ford/mercury/lincoln with the 4 wheel disc brake option. Later, Randy
      Oregon
      Quote Originally Posted by blyth18md
      Yes...and the early Bronco guys jump on them in the yards like a Chihuahua on a pork chop, so if you see one, better grab it fast.
      It's what I does.
      Hazlehurst, MS
      I'm running one from an astro van. It works great and dosn't seem overly sensitive.
      pittsboro, nc
      Quote Originally Posted by chevella
      have any photos?
      what was your cost?
      68 camaro ls1 restomod
      Houston, Tx
      Quote Originally Posted by shanekennedy
      have any photos?
      what was your cost?
      I have one from an Astro as well.
      Bought the unit for $50... I am going to use it as a core for a new one at advanced auto (final cost will be $130 for a reman). I am using an LS1 Master and power brake booster brackets from summit. I will be in the whole setup for about $250 when all is said and done.
