      Virginia
      4 Link with tailpipes?
      Just wondering if anyone is running a 4 link rear and is able to run tailpipes out the back. (69 Camaro) I was thinking about using air ride Technologies Air Bar but they are running the tailpipes under the axle. Is that the only way? Also heard it is hard to run tailpipes on the DSE Quadralink, is that true? How bout other brands.
      Virginia
      I just found a post of DSE and their Quadralink and tailpipes. They now make their gas tanks so they can get the exhaust through.
      Aug 2003
      We sell a lot of notched Rick's tanks for 4 link exhaust clearance
      Virginia
      Anyone running an Air Bar setup with a notched fuel tank and tailpipes?
      Jan 2007
      An alternative
      I am running a 3' torque exh w/ series 50 flowmasters in a 68 Camaro with An air ride Tech rear Tri 4 bar but with coil overs. I am lowered at least 3-4' from stock and there is no room to run the exh over or under the axle. Right now the exh dumps down right in frt of the axle. I am going to exit the exh in frt of the rear tires using Dr Gases 3" to 2 x 4 oval pipe kit. With the longer 50's instead of the 40 series I am going to have to actually use more than 90 deg bend and bring the pipe actually forward and then back to the exit point. They build most of the exh systems for NASCAR the link is http://www.drgas.com
