    Results 1 to 1 of 1
      Aug 2006
      Turbo 350 crossmember
      Well its getting close now. We finally set the engine (383 stroker) and trans (turbo 350) in the car (69 Camaro). I did run into a snafu though. There are only two crossmembers listed in every catalogue I have for this car. One is for the Powerglide, fourspeed and 350, and the other is for a turbo 400. I ordered the correct one and the trans mount and the holes in the crossmember do not line up. The trans mount is about an inch and a half longer (toward the rear end) then the holes in the crossmember. This car was originally a six cylinder car but I don't think that would be an issue. The holes in the subframe should be in the same place either way. Not wanting to pull everthing out at this point, do you think making a bracket that mounts the crossmember to the trans mount would be alright? It lines up fine side to side and the holes are parallel to each other. The bracket would have four holes in it and would simply be to span the inch and a half gap. Has anyone else run into this problem? KB
