      Woodbine, MD
      Road Race vs. Auto Cross
      I was just thinking about this. When I had my 83 spec rx7 running in the SCCA...we all had the Diamond Racing wheels...steel..cheap and affordable to mess up (gravel, grass, curbs?). Pretty much every race car out there had these type of wheels.
      Now I go to the autocross...and it seems like some of the serious racers have these same rims but most people out there are just on there usual rims. And most muscle cars (PT cars) I see out there have the big expensive rims. So heres what im getting at...if I do mostlly autocrossing in my monte...should i worry about messing up some nice rims?? The only thing to worry about would be the sidewall rolling over...but how likelly is that?
      So..should i go for the cheap steel wheels...or get some nicer wheels?
      Feb 2006
      Brampton, Ontario, CANADA !!
      Well, if you want to be very competitive in auto-X, you'll need to get a set of dedicated race tires made for that purpose. So if you're trying to not blow the bank on the whole deal, a set of steel racing wheels to mount those extra tires on would likely be a good idea. Unless of course you can get a good set of used alloy wheels for the same money or less, that don't weigh any more than the steel wheels.
      cheers
      Ed N.
      Ed Nicholson
      73 VW Super Beetle "Sports Bug"
      95 Taurus SHO 5-speed -- new open-track beater
      Loganville, GA
      SicMonte,
      In 4+ years of autox, I have yet to damage a rim on course. The one to make sure is you have enough air pressure. I have seen one picture with the rim edge almost touching the ground, the tire needed more air in it. So you can run nice wheels if you want to. Unless you drive like this ->
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Woodbine, MD
      ok thanks for the advice. On my rx7 I was running shaved toyo ra1's. What is a good tire for the autocross?
      Nov 2004
      When I was road racing at the regional level, we all just bought the cheapest aluminum wheel we could find. Looks didn't matter and they tended to get banged up anyway. With cast aluminum wheels, I found that they had a service life and would eventually start to crack around the stud holes. Not a big deal, but you had to watch them. The aluminum Baer hubs were the same way. When I moved up to Motorola Cup/Grand-Am Cup, most teams were running the big money wheels. It's all about the budget.
      We ran Toyo RA1 tires for years and they are an awesome road race tire. Not quite as fast as a Hoosier or Goodyear, but we could get about 4 race weekends out of them as opposed to 1 or 2 weekends with other brands. They need a few good hard heat cycles before they start to work. They also take about a full lap to 'come in' so they might not be the best choice for short-duration autocross.
      Just my .02.
      Feb 2007
      Kuhmo makes an autocross spec tire that comes up to temperature in 1/2 a lap.
      Toyo does too. It looks like the RA1 but it has a different compound.
