Thread: Timing Set Questions
02-13-2007 #1
New to Pro-Touring
- Dec 2006
- Northern Ohio
- 9
I am researching my next project, a 400 chevy, and I am going with the Comp Cams new Thumper Series Retro Fit roller camhafts, the Mutha Thumper Cam. I am going with Comp Cams retro fit hydraulic roller lifters, 1.5 stainless roller rockers, Beehive springs with this cam. My question is this, do I have to use a special timing set or can I use my double roller set? I understand that I have to use a thrust washer to protect the block and a cam button to keep cam walk in check, but I am not sure of which timing set to use, is there a difference? I see sets out there for use on motors that are using retro fit roller cams and are considerably more expensive. Any help would be appreciated.
