    Thread: spot welding
      Jun 2006
      spot welding
      im currently in the process of reskinning a 1969 camaro, im wondering if you guys have some pointers on welding. this is my first attempt and im getting better, but taking a long time. when i weld up my spot welds,(using a mig).. im stilll left with some indentions
      after grinding. do i go back and lay more weld or fill in with filler ?
      You can chase indentations in plug welds (MIG version of spot weld) for a long time, each time putting more heat into the panel. Heat is the enemy of straight panels, except when trying fix them.
      If the welds are sound, (indentations just a fraction of the panel thickness) then I'd go with body filler if a perfectly smooth result is desired. For welds that can't be seen, I would prep, prime, and paint.
      jp
      ​John Parsons
      Jun 2006
      spot welds.
      thanks for the info, by the way what size holes do you drill for a spot weld, i think im drilling too large, im having trouble filling the entire hole with weld. .. i know im an idiot at this, but im tryin !
      Oct 2005
      Odessa mo.
      5/16 is the size reccomended by ICAR and is the industry standard.
