    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 60 of 61
      Eastern Virginia
      Hey Frank,
      Anything new on the Monte?
      Scot
      86 Monte SS
      Aug 2003
      Michael got the frame cleaned up and sprayed the underhood. Got the Front Hotchikis kit on it today (nice stuff I tell ya) and started on the rear suspension. Frame notch is done and he is working on the flare everyday a little. Motor is freshened. Year One is the goal, so he has to hustle!
      I get his camera and post some pics soon
      Aug 2003
      Maybe you guys can help me. What kind of spindle can be swaped to these cars, without going the sftermarket spindles. We would just LOVE to do ATS spindles, but we to stay on the cheap. Were kinda clening the shelves on this project. We have some Wilwoods we want to put on it. But with the original one piece spindle / caliper braket, there is no brakes available.
      Eastern Virginia
      A body spindles with 12" brakes using aftermarket upper A arms, & F body 1LE rotors.
      I have 98-02 S10 Blazer ZQ8 spindles with factory style upper A arms. ZQ8 spindles use 2 piston calipers & a slip on rotor similar to Vettes & F bodies. I used the spindles but used it with C5 13" rotors & calipers.
      Scot
      86 Monte SS
      Aug 2003
      What year A Body?
      Eastern Virginia
      Here is info on Global West's website that will tell you what cars you can get 11" or 12" brakes from:
      http://www.globalwest.net/G-body%20d...nformation.htm
      Scot
      86 Monte SS
      Nov 2004
      EVERETT WA
      Sounds like a cool project, can't wait for pics, and details on the wheel fitment! keep up the good work. Paul
      b-body spindles are easier to find ...caddys,olds,etc
      Eastern Virginia
      I have a set of B body spindles in the garage. No calipers or rotors though.
      Scot
      86 Monte SS
      Eastern Virginia
      Frank, any updates on the Monte?
      Scot
      86 Monte SS
      Aug 2003
      Getting uglier by the minute. Found a killer door this weekend, Motor is about to go in, but possible 11th hour change. It will all come togther at once.
      The flares have been a LOT of work. I think we will have to mold them to recoup some of our time, LOL! I think they are going to look dead hot though.
      Wilwood makes an aluminum caliper that will BOLT ON the B body spindle. I have a brand new set if you are interested.
      Mike
      www.musclecardeals.com
      Aug 2003
      Quote Originally Posted by vintageracer
      I am making brackets and may very well sell a kit. These cars need some good brake ptions and Wilwood does not have these on the radar. I will probably do a 12.2" four piston and 13" six piston set up.
      Frank,
      The Wilwoods I have are the very same calipers that all the Saturday night racers use on these B body cars at the local Saturday nigh Nascar tracks. A STOCK B body caliper has a clamping pressure of over 2800 psi per GM specs. This is as much or more than a lot of "racing" calipers. Stock B body calipers or the Wilwood bolt on aluminum caliper will give a G body GREAT BRAKES in the front.
      You are on your own on the rear brakes!
      Mike
      Aug 2003
      Here is a pic of the GN Flare, just a few slight modifications. I have decided to sell them when they are finsihed. I will get pics tomorrow but we have the 2 right ones roughed in. Once done with the plugs, we will mold them and make a set for this car as these are getting REAL heavy! Were going to being pushing it getting ready for Year one, but I guess we would have it no other way, LOL!
      Farmington Hills, MI
      New Pics?
      Jeff
      JEFF SHORTT
      -IDEAL STEEL
      Eastern Virginia
      Wow, looks like a lot of hacking & wacking to get them to fit.
      Scot
      86 Monte SS
      Nov 2004
      EVERETT WA
      Hi Frank, Are you going to sell a fitted version, or those modified flares, would love a set for Elky! how long and how much? Keep up the good work and update on wheel sizes etc as finished. thanks.
      Aug 2003
      Quote Originally Posted by 65convertible
      We will, I am guessing the flare kit will be about $400 a set for quality Vinylester resin pieces. As for tire sizes, I know the rear will take a 335 on a 12" rim, on the front I am thinking with the flare we can probably run a 11 inch wheel and a 295 or so tire. On this car we are using a set of wheels and tires we have, so we probably will not take full advantage of the front possibilities.
