    Results 1 to 11 of 11
      CT
      Basic cost of install?
      Hi all,
      I know I have lots of reading to do but maybe I can get a push in the ls2 direction..
      I am sick and tired of carbs! I was planning on rebuilding my 350 and bolting on an EFI system this year. I was not planning on reusing my short block just my Edelbrock heads. My friend and I were discussing how much better a LS2 is but the additional cost might put the brakes on that upgrade. What am I really looking at for a basic swap? I’m not thinking about the cost of the engine just the rest required to drive again. I can do all the labor myself (hopefully).
      The fuel system is a wash since I’m going EFI regardless.
      Headers, wiring (w/ computer), mounts (I can make?), Shorted drive shaft, pulley mounts.
      Am I missing anything? Can I use the new 700r4 I bought last year?
      Thanks guys
      Burnaby, BC, Canada
      Bill first have a read through this thread: http://www.ls1tech.com/forums/showthread.php?t=472609
      It might give yo a better idea of what's involved. Cost will depend on a few things, if you get a complete motor with accesories, wire harness & PCM (which I highly recommend) I'm pretty sure a 700r will work, do some searches on www.ls1tech.com in the conversions/hybrids forum otherwise check out S&P www.hotrodlane.cc
      The install would also depend on how high a quality of parts you want? LT headers, shorties, SS EFI tank, custom rad/fans etc or just trying to re-use the 4th gen rad/fans or mod the stock tank as some people have.
      My guess with a complete motor & tranny setup $5K low to $10K high.
      1969 CAMARO RS
      Project pics of my '69
      Lateral-G Feature Page
      pittsboro, nc
      here's some ballpark #'s
      7500 used ls2/tranny
      500 pcm/harness mods
      150 motor mounts
      150 tranny x-member
      600 fuel tank/pump conversion
      100 fuel line
      400 oil pan
      400 drive shaft
      500 radiator/fan
      500 cable driven throttle, if you don't link drive-by-wire
      68 camaro ls1 restomod
      CT
      Thanks guys,
      Maybe I should just bite the bullet now and make the conversion.
      The cost isn't as bad as I thought since I was going EFI anyways.
      Thanks for the links there going to be real helpful!
      Houston, TX
      You may want to look into an LS1 or LS6. You can usually pick up an LS1 for a lot less than an LS2
      Phillip Lawrence
      1969 Camaro
      LS2 with a Kenne Bell
      Jul 2003
      Anaheim Hills, CA
      I bought my 2000 LS1/4L60e combo for $2800 delivered.. there are deals out there if you look. Oh, it had the harness and ECU also, but it looked like hell.. lol
      1968 Track Rat Camaro:
      Huntington Beach, CA
      Don't forget the price of headers. They are crazy expensive if you want a good set.
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by Chad-1stGen
      Well, if you going true "low buck" you could use the factory manifolds.. the newer ones flow pretty good
      CT
      The way Im thinking is for this year just get it up and running then buy the pretty and fast stuff gradually. LS1 might be the way to go unless I can score a great deal on a LS2. What about the trans, can I reuse the 700r4?
      Aug 2005
      Hackettstown, NJ
      I'm going to go with the LQ4 6.0 out of the truck. They are only around $1800.00 with all assories and ECM. It is a little heavier because it doesnt have an alumium engine block. But for me that just means that I do not have to worry about changing my spring rate. From what I have researched the 700r4 will work with an LS engine you just need to get a flywheel spacer from a chevy truck it is a GM PN or I think this might work http://store.summitracing.com/egnsea...18185&D=318185 . Also you can get the kickdown TV setup from bowtieoverdrives.
      Aug 2005
      Hackettstown, NJ
      Sorry link doesnt work but go to summit and this is the part number HUP-HP3795.
