    Results 1 to 10 of 10
      Atlanta GA
      Changing Bolt Patterns... this possible?
      I was thinking about changing the bolt pattern on the Bonneville to a chevy bolt pattern seeing that there is more available in that perticular pattern.
      the bonnie is 5X5 and that is still around and such but there is ALOT of 5X475.
      does anyone know what might intail as far as changing to a chey pattern?
      How about a nice set of Impala SS rims. I bet you could get a set of used cheap.
      Atlanta GA
      meh, not my cup of tea.. thanks tho!
      i was thinking that if i change my bolt pattern that if i ever want to share wheels between my camaro and bonnie or if i ever got tired of the wheels on venomus that it would be a cool switcheroo..
      Nov 2004
      Memphis,Tn
      It is actually pretty easy to do. You will have to pull the axles and take them to a machine shop, they can redrill them for you just let them know what bolt pattern.
      May 2002
      Northern California
      I do them my self now but the first time I did it I knocked out the studs, used a brake rotor that fit over the hub and drilled the holes on my drill press. Using the rotor as a guide.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      bellingham,mass
      ive been thinking bout doing the same thing..my bonny('78) has the 5x5's and it is a PITA trying to find nice rims...even though from what ive seen alot of the rim companies can drill rims to that size..but ive never priced it....also if you look at "truck" rims..most of the full size trucks ran this bolt pattern..many rim manufacturers separate the truck rims from passenger car rims....im thinking bout going to a 5x4.5 or whatever the camaro bolt pattern is then i can use some factory wheels..always seeing deals on corvette take-offs on craigslist..just missed out on a set of 17x9 and 17x11 '96 vette rims that woulda looked cool..oh well...oh one more thing i think i read that late model jeeps(cheeroke and the like) may use the 5x5..but not totally sure.....
      Fontana, CA
      Try having 5x5.5. That really sucks.
      Any machine shop s/b able to do it.
      Nick R.
      Atlanta GA
      so just take the axles and drill them using a 5x475 rotor as a templet and putting in new studs will work?
      if thats all it takes then thats the next move..
      Mar 2002
      Redwood City, CA
      You make it sound like it's difficult.....
      Allen Ortega
      Atlanta GA
      well you know that is the sign of moronism.. ahhahah
