Thread: Hotckis vs Eibach
Hotckis vs Eibach
All,
Im new to the forum but need help. I recently purchased a 69 cutlass convertible. I have the front end down to the bare frame and am starting to order some suspension parts. My goal is NOT to make this a slalom racer, but a nice driver that has a nice look to it. I DONT want to be doing it again next year though! Heres my big questions;
1. Springs. Im considering the hotchkis or the eibach springs. Eibach is 1.25" drop vs Hotchkis 1". Has anyone used these on an A body and which is better (ride/perf)? The eibachs are less$$,
2. Shocks; Are KYBs okay? Is there something better at a comparable price?
3. Front end components; tierods, ball joints etc. Whats decent? I found a kit on ebay that is a brand by coni-seal called "chassis 500". I thinkthey sell to the major parts houses. Im mostly concerned about quality here. Not necessarily the highest of performance. I looked at the polygraphite kit from PST, and it was 400 bucks. It thought it was overpriced for what I needed. Any thoughts?
Keep in mind I am on a budget,I have already gone too far! I drove the car for 2 hrs, and next thing you know, the whole front end is off. (I got it January 1st!). Any help would be greatly appreciated as I want to order these components on monday!
02-03-2007 #2Well I have every Hotchkis suspension part on my car, even the tie rod sleeves, minus the rear sway bar but i did the 2'' drop in the front, not 1''...and I used the Koni Special shocks with allow quick adjustment of the shocks rebound and stiffness for $99/pr. Its not on an A-Body but the ride is pretty stiff when cruising over little imperfections on the road but when it comes time to cut corners at high speeds there is nearly NO body roll on my car, even wheel hop is gone with the rear.
As for KYB shocks there great shocks for the price, but for a little more dough you can get alot better
For your front end, id use all MOOG Chassis parts, NASCAR proven and the wont snap under pressure (unlike repo. stock ones I had)
Since your not looking for a slalom racer then TRW chassis parts are good and cheap also, check your local advance auto store (used to work for them) TRW brand parts are very reliable and super cheap
Hope this helps a little
02-03-2007 #3
- Aug 2004
- 830
the eibach springs need to be cut alittle bit to get the car at a decent ride height. they made may iron headed small block camaro sit pretty high.
02-03-2007 #4I am leaning toward the eibach springs. Looking thru some other threads, I looks like they should be okay. Im not too worried about the front being too high, Id bet my Iron headed olds small block with AC is a bit heavier than your camaro!
Looks like an inexpensive, nice riding shock may be the KYB GR2. Again from other threads, it looks as if the gas adjust are a bit stiff, and Im looking for something that rides decent.
I can get that combo to my door for $317 from Jegs...very reasonable.
Still undecided on the front end stuff. Moog is pricey and do I really know what Im getting from NAPA?
02-03-2007 #5
- Aug 2004
- 830
I'm running kybs right now and they are functional but do ride alittle stiff.
Im also running ball joints from napa... havn't had a problem yet.
alot shops that work on OEM vehicles get their parts from napa. If the stuff wasnt good they would have some big promlems on their hands
I do not think you'd have a problem
