Results 1 to 12 of 12
01-30-2007 #1
Piston -> Valve clearance checking
I finally got my 454 short block completely re-assembled and last night I started checking piston to valve clearance. The pistons are factory 11.25:1 pop-ups and the cam I'm using is a hydraulic flat tappet (241 int./249 exh.duration @ 0.050" & 0.572 int./0.590 exh. lift with 110º LSA). Rather than use a hydraulic lifter for clearance testing, I used one of my old solid lifters from the previous cam (so I didn't have to deal with the hydraulic lifter bleeding down). I used a pushrod length checker and with this combo, and the stock pushrods were perfect length.
I mashed some clay in the valve reliefs, slapped on the Fel-Pro head gasket (0.039" thick) and tightly snugged the head in to place. Next I set the valves to zero lash plus 1/2 turn. When I pulled everything apart and measured the clay thickness, the intake was 0.060" and the exhaust was 0.050". I've read and been told that you need a minimum of 0.100" intake and 0.080" exhaust with a hydraulic flat tappet cam. I tried the same thing with only 1/4 turn past zero lash and ended up with 0.080" intake and 0.070" exhaust.
Obviously I'd prefer not to pull the bottom end back apart and have the pistons reliefs flycut for extra clearance. I can go to a 0.042" head gasket, but that's not going to gain me enough. The one thing I noticed is the "cup depth" of the solid lifter I was using was much deeper in to the lifter than the hydraulic lifters that will actually be used. This will throw off my pushrod length (they'd be shorter with the hydraulic lifters) and not allow me to use stock length pushrods. Not a big deal, but would that have any impact when checking PV clearance? So what are my options now??
Dan
01-30-2007 #2
- Sep 2004
- Chicago - western burbs
- 681
Dan...I'm no expert, but I dont think the pushrod length itself will have an effect on your measurement, but the proper positioning of the rocker tip on the valve may have a few thousanths difference if it is way off, but not enough to give your measurments.
Also, why are you going past zero lash with the solid lifter? I think that may be your problem. That will open the valve slightly making your "lift" that much higher.
01-30-2007 #3
01-30-2007 #4
- Nov 2004
- 504
If you are close to minimum clearance, I would recommend checking P-V clearance using the 'valve drop' method. IMO, it's far more accurate than the clay method. Let me know if you would like details on how to do this.
01-30-2007 #5
01-30-2007 #6
- Nov 2004
- 504
Yep, that's the method. Here are the key steps:
Originally Posted by dhardison
1) Degree the cam and leave the degree wheel in place
2) Install the heads with lightweight springs and without head gaskets
3) Mock up the valvetrain on the cylinders you want to check using the solid lifter.
4) Rotate the piston to 15 degrees BTDC
5) Put a dial indicator on the valve retainer and zero it out
6) Push down on the retainer until the valve contacts the piston
7) Read the dial indicator for P-V clearance
8) Add the compressed head gasket thickness to get 'true' clearance
9) Repeat process every 3-5 degrees up to 15 degrees ATDC
Let me know if you need more details. --Neil
01-30-2007 #7
01-30-2007 #8Neils method is by far the best one for checking P/V clearence i'd say....i think the closest P/V clearence you will have is at 10 ATDC & BTDC......cant remember exactly.
-Carm'69 Firebird Twin Turbo SBC 400" Blow-through
9.80 @ 141 w/ 1.88 60-ft..... on 17's
9.21 @ 153 w/ 1.45 60-ft..... on PUMP GAS
8.60 @ 164 w/ 1.46 60-ft..... on RACE GAS
01-30-2007 #9
- Nov 2004
- 504
Yep, minimum clearance on the exhaust valve is normally at 10 degrees BTDC (at the end of the exhaust stroke when the piston is chasing the valve). Minimum clearance on the intake valve is normally at 10 degrees ATDC (at the beginning of the intake stroke when the valve is chasing the piston). So, you really only need to check clearance from 15 degrees BTDC to TDC on the exhaust side and from TDC to 15 degrees ATDC on the intake side.
Originally Posted by Turbo Hen
Also, I like to use the clay method in addition to the valve drop method because the clay method shows radial clearance between the valve and valve relief. It's also the only way to check spark plug to piston clearance (critical with domed pistons).
01-30-2007 #10You're right Neil......i never used dome pistons anyhow lol
01-30-2007 #11
