    Results 21 to 40 of 41
    1. #21
      Aug 2006
      thank you John i am having fun, it is so much better to look at pics like this, i hope everyone does it i love this web site and all the forums,and thanks for all the input ..Barry
    2. #22
      Aug 2006
      Duster dan that was the easy side wait for the drivers side i am going to try and make them look some what the same....
    3. #23
      Aug 2006
      I have a question i hope someone can answer if i stay with an automatic does ford make a overdrive transmission that would handle up to 700hp and 600 ft lbs of torque...other wise i might have to run a gear venders overdrive unit and it costs $2800.00 alone.....
    4. #24
      Aug 2006
      the mav gets 315`s
    5. #25
      California Bay Area
      315s on a maverick now were talking..the header does look pretty good,keep the pics coming
      65 Impala
      01 Z06
    6. #26
      Feb 2006
      SoCal
      I use to own a maverick when I was 17. I wish I would have kept it. AWESOME project!!
      ***Under Construction***
      Build Update Link:
    7. #27
      Jan 2007
      Phx, Az
      DAMN!! 315's .. looks like they might rub the fender??
      1973 C10,400sbc, Baer Brakes, 4 link,TOYO tires
      2010 Charger RT
      __________________
      Joe
    8. #28
      Aug 2006
      Yes right now they are rubbing on the fender but i just had to see what it would look like they will move in about 1 1/2 inches when i mini tub it and move up in the wheel well a bit ......
    9. #29
      Wilmington NC
      That is awesome!!!!
      Very nice!
    10. #30
      Quote Originally Posted by aussiebj
      these guys can build an AOD that will live behind a 1400hp engine so i'm guessing they could build you one for the 460 with no problem at all. they also have bellhousing to adapt the AOD to the 460 as well
      http://www.lentechautomotive.com/
      Do you have a 69 or 70 stang? If so then check out www.69STANG.com
    11. #31
      Nice project, I need you to write me a build book for your car. I need to read & learn more from you. That would include welding. I new I could fit a 315 on the back of my car. My backspacing must not be right. I have 295's & I also had to get a mini tube to fit them. The 460 is a very WTF factor.
    12. #32
      Aug 2002
      Waleska Ga.
      Cool Project!!
      We are doing one for Comet Chicks dad that will fit 335's on the back, relocated the rear frame rails in about 4"s on each side.
      Keep us posted.
      David Sloan
    13. #33
      Jan 2007
      Phx, Az
      Quote Originally Posted by d touring
      Cool Project!!
      Keep us posted.
      Did you guys just make your own rear frame? Im about to start doin this to my falcon, just lookin for different ideas.
      2010 Charger RT
      __________________
      Joe
    14. #34
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by LMDGUY
      No we used the stock frame rails cut them loose from the inner wheel tub an the trunk floor on both sides then moved them in about 4" cut about 8" out of the center of the trunk pan welded it back together.
      Then you pick your rear suspension, cut the rear end to the desired length.
      Hope this helps
      David Sloan
    15. #35
      Aug 2006
      I have enough room to just cut the inner wheel house back to the frame rail, and if i wanted i could reuse my leaf springs but i am going with an Art Morrison triangulated 4 link set up..
    16. #36
      Aug 2006
      streetrod 77 when i am finished i could put a photo dvd together for you with all the detailed pics if you want.......
    17. #37
      That would be great. I will look for that when you get around to it. I want to go with 335's now since I know it can be down. I really need to learn how to weld before I tackle a job that big. I had to pay someone to do the mini tubing for me & it didn't look hard but I cant weld so I couldn't do it. Thanks for the helping hand.
    18. #38
      Jan 2007
      Phx, Az
      Hope this helps
      cool.. any pics?
      2010 Charger RT
      __________________
      Joe
    19. #39
      Aug 2006
      I have decided to sell all my projects to spend more time with the family ..see 4 sale section...thanks for all the help Barry
    20. #40
      Jan 2007
      Phx, Az
      2010 Charger RT
      __________________
      Joe
