    Results 1 to 11 of 11
      The Netherlands
      Country Flag: Netherlands
      ball joints removing spindle
      My subframe (2nd gen Camaro) is separated from the body, engine is out and I need to remove the spindles. I have a hard time getting this job done.
      I tried with a ball joint fork but it still won't come loose after several blows with a big hammer on the fork.
      (castle nuts are a few turns loose)
      Tips/advise anyone??????
      Martin
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
      Nov 2004
      get a splitter:
      The Netherlands
      I have one like that too....but they are WAY too small.....
      1st 2nd
      Newbury Park, CA
      1) Confirm that the fork is the correct width.
      2) Hit it harder.
      Nov 2004
      Get a larger fork or a larger splitter.
      The Netherlands
      How do I know what the correct width for the fork is?
      The splitter I bought is too small, the fork I have is pretty large...I can measure it (maybe tomorrow night)
      Martin
      1st 2nd
      Feb 2006
      Elk Ridge, Utah
      If your not going to use the spindal again Or dont care if you mark it a bit then .
      Hit the spindle with a hammer on the side to distort where the ball joint comes through it. it will come loose in a few whacks..
      been doin it for years never seen any bad results other than a few hammer marks
      69 Camaro
      W/D sub, Wilwood 13" brakes Bozeforged wheels 18X10 & 18X12,
      Lateral dynamics 3 link ( custom setup ) Dana 60
      lsX Twin Turbo, soon to come
      Viper T56 in place (Yay)
      Bought a running driving car so I can enjoy it before Im dead
      LD 3 Link Installed into ^^^^^ (Yay)
      May 2002
      Northern California
      ...i agree, wack it off....damn Durango and liberty's. But good practice. 3-4 wacks on average. Leave your shock and sway bar hooked up so the spring doesn't go north.
      Like this...
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Newbury Park, CA
      The inside of the fork should be just large enough to allow the balljoint shaft to fit into. The majority of both forks must also be in contact with the spindle.
      The Netherlands
      thanks all! I will give it another try next weekend....
      Martin
      1st 2nd
      The Netherlands
      Well....I managed to get it all loose! I think the fork I have is just a bit too wide.
      I also found that the fork was more effective from the rearside. Last week I tried it from the front........
      Alltogether this job was a major PITA.....but that's done now
      on to the next job now.
      Thanks everybody for your advise!
      Martin
      1st 2nd
