    Results 1 to 12 of 12
      Aug 2006
      Hampton Roads, VA
      Sanity Check--Solid Motor Mounts?
      Solid motor mounts like this for my primarily street-driven car--good idea or no?
      Would there be a handling/throttle response difference enough to make them worth it, or would they just rattle my teeth out on the street? Anybody run them in your PT car?
      1980 Pontiac Trans Am, Chevy Big Block 468, TKO 600 Trans, Hotchkis TVS, Bilsteins, Eaton/Motive 3:73's, 18" Coddington Junkyard Dogs, Nitto NT555 rubber, Autometers http://www.fquick.com/Bandit
      http://www.cardomain.com/ride/2458763
      Indiana
      My Vette has a solid mount on the driver side and a rubber mount on the passenger side. It's not bad at all. I don't know how it would be with two solid mounts.
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Petersham ,ma
      i have a soild on drivers side and regular on the pass side, its fine except when your idleing.....makes the whole car shake! going down the rd you would never know.
      California
      Yup, I got a solid and rubber, too. I haven't noticed much of a vibration increase anywhere (specifically at idle).
      I don't think there'd be an increase in throttle response, but it's cool to rev it and have the whole car move.
      Matt
      Nov 2004
      Country Flag: Netherlands
      both solids and a urethane trans mount.
      Both solids and a rubber trans mount here I dont mind it at all but I will be putting a ruffer cammed motor in soon so my mind may change.
      If your running a small block make sure you dont use a newer melling oil pump or it will break. You need a Mselect pump.
      Dec 2002
      Lost Wages, Nevada
      I ran solid engine and rubber (or poly) transmisson mounts for years... and loved it. Solid engine mounts to tend to stiffen up the front cradle, which is a good thing for turning corners. I would not... run solid engine and trans mounts on a street chassis.
      However, if your engine uses a "knock sensor"... I would also advise against using solid engine mounts. Specifically if you are going to run an "LS" series engine.
      Southern Indiana
      I have built several cars with engine plates and had solid mounts in my 70 Monte Carlo from the day I put tit together and through 2 small blocks and a big block. I still have those mounts too cause I made mine.
      I have never had a problem with either big or small cams.
      Fontana, CA
      I use solid mounts and Poly trans mount. No problems but I have a 114 LSA Roller cam so that makes a difference at idle.
      Nick R.
      Quote Originally Posted by chicane67
      I'm running solids with a lsx motor, while it is stock, it never triggered the knock sensor when it was on the dyno and it has never once thrown a trouble code. Nock sensors can also be desensitized.
      Stuart Seitz
      montgomery, IL
      hell id do it
      "Too bad Dare to Be Different these days could mean Dare to Be Fast. What ever happened to the Cars that Scared people?" John Pearley Huffman
      Oct 2006
      solid on last car, motorplates on current, not a prob, cars cooler shaking at idle imho
