Thread: 550-600 hp sbc
01-25-2007 #1
550-600 hp sbc
Ok, here's the scoop. I have a 385 cid sbc, 6" rods, 58cc corvette heads (1.94 I & 1.50 E valves) making 10.4:1 compression. The cam is comp. 08-422-08 hyd roller, gross valve lift is .495I & .502 E with 218I and 224E duration. I'm running a holley stealth ram FI system. I'm looking to get 550-600 hp out of this engine. I've thought about supercharging/turbo charging it but, I can't make up my mind. Looking at what I have what changes would you make to acheve that range in hp? I would like to spend $2-3,000 at the most. PLEASE HELP!!!!!!
--- I'm running eagle steel crank, I-beam 6" rods & forged pistons. Horese power now is up known I'd say 450ish from what the engine builder says.The trans I'm going to be running is tko600 and the rear is a dana 44 from a vette. just to complete the picture.
