      Jan 2007
      Atlanta, GA
      Wheel Spacer Question???
      Could someone explain to me what is the deal with wheel spacers. How do they work, what do they look like, and what are the pros and cons?
      The reason I ask is because all of the wheels I want for my ride dont come in the bolt pattern that I need? Thanks guys
      Jan 2007
      Think of them as just a big washer that goes between your rim and spindle or axle. They just move you wheel out or widen your stance by what ever the thickness of the spacer is. They are usually drilled to fit more than one pattern. They will not help you mount a rim that doesn't have the right bolt pattern to fit your veh. When i figure back spacing i will error on the side of too much back space, That way if I need less I can add a spacer. If i need more I'm in trouble.
      If you're looking to change bolt patterns or need a spacer greater than 1/4" you need WHEEL ADAPTERS not wheel spacers. These are basically extensions of the hub. They bolt to the stock studs and they have their own studs installed (that's how you can convert to a different bolt pattern) that you bolt the wheel to. If this is what you plan on using, I would suggest going one step further and getting a wheelcentric lip machined on the adapters to center your wheels.
      Brian Escamilla
      '81 Sport Coupe 229 V6- Junked
      '94 Z28 - Parted Out
