    Results 1 to 11 of 11
      florida
      subframe bushings, squished??
      When I line everything up and torque the subframe mounts my front mounts end up being all distorted. I redid it 4 times now and as soon as I torque them past 30 or so they look like this. Is this normal??see pics here.
      http://i75.photobucket.com/albums/i2...an/mounts1.jpg
      http://i75.photobucket.com/albums/i2...an/mounts2.jpg
      Oct 2006
      So Cal San Dimas Ca.
      Did those mounts come with any type of sleeve,if your old ones had them reuse the sleeves
      Or better yet, use solid bushings.
      florida
      they came with sleeves that interlock and they are installed
      florida
      theses are the energy suspension mounts.
      florida
      how much are solid bushings??
      California
      Good ones are about a hundred. Like the ones from Global West (which I have on my car ). They're like the OEM bushings in that there's an upper and lower bushing for each mounting point, whereas cheaper ones like Moroso's only have one bushing for each mounting point. I honestly think the bushings made more of a difference than the Hotchkis front springs. They're that good. And it doesn't ride any harsher than with rubber bushings. I really see no reason to use rubber or poly.
      Matt
      Quote Originally Posted by DarkoNova
      Matt
      I agree with all of the above 100%.
      Jan 2007
      After I instalied the G/W solid mounts on my 68 Camaro I was scaling and leveling my car and found the frame and body were not parallel. In other words when I got the body level with the ground the frame wasn't and visa versa. To get everything parallel I measured the differences and had the to mounts cut in a lathe and reinstalled until everything was parallel. There was nothing wrong with G/W mounts, they were all the same size, it was in the distances between the sub frame and body. I don't know if this is common or maybe the car had some damage at some point. No visable damage apparent.
      florida
      Wow, thanks for all the input, I will order the solids, why cut corners now!
      California
      Quote Originally Posted by dgoetz
      Yeah, when I put them in my car, the driver's side fender stuck out a bit at the edge near the door (where the little vent/cowl thing is). A looong time ago, I took my car to a suspension shop and they said the frame was bent, so perhaps the stock bushings were squished/deteriorated enough to make it look fine, and the solids showed it for how it really was?
      I don't know, but I don't care, it was simple enough to fix.
      Matt
