    Results 1 to 15 of 15
      Jun 2006
      First post, My project 71 SS Nova
      Hey yall, here are some Sneek peek pics of my project 1971 SS Nova. Hopefully will be completed in three months( if i am on scheduel....) .
      These are 20X10's in the rear and 19X8's up front. I Have 295 30r 20's in rear( could have gone with 315, next time...) ANd 225 35r 19's in front.
      http://viewmorepics.myspace.com/inde...eID=1755582288
      http://viewmorepics.myspace.com/inde...eID=1755594589
      http://viewmorepics.myspace.com/inde...eID=1755602934
      http://viewmorepics.myspace.com/inde...eID=1755611801
      http://viewmorepics.myspace.com/inde...eID=1755769215
      http://viewmorepics.myspace.com/inde...eID=1755777753
      Lil info for now:
      air ride all four corners with a custom lader bar setup in the rear.
      2'' drop spindles(havn't installed yet)
      Poly bushings all around
      Front sway bar, soon to have rear.
      Sub-frame connectors.
      All wheel disc brakes.
      Thats about all i can think of for suspension mods right now, Other then the mini-tub and custom inner front fenders.
      Rennskii, soon to be cookin.... Yeeehaaawwww
      ROBBIEVILLE
      Country Flag: Great Britain
      hmmm
      Sick mate !! looks good
      wanted to go 19s as well all around what type of rims are those and where did you get them .... there are not to many 19s around and I really want to get a nice set ... for my 66 gto
      1966 GTO HELL BEAST PROJECT
      Delaware, OH
      Lookin' good! I like the wheels! What are you running for a engine/trans?
      St. Augustine, FL
      Lookin good.
      Andrew Petty
      So Cal
      Sweet car!
      Add another nova to the Pro-Touring.com family
      Petersham ,ma
      Love The Rims What Kind Are They?
      Jun 2006
      Thanks everyone for the comments.
      The wheels are a TSW thruxton one piece wheel. With Proxes 4 tires.
      Engine and tranny:
      Slow little 350 backed with a dieing th350...wink wink... ; )
      ok ok,
      350 bored over .040
      World Sportsman II heads(port and polished)
      (TRW)Sealed Power 4v Flat top Hypertuetic pistons
      Manley roller rockers/lifters with manley pushrods
      Hastings Chromemoley piston rings
      Clevette 77 berings
      Competition camshaft,tappet lift 280 Degrees, lobe seperation is 110 degrees/ gross valve lift .480, Duration at .050 is/ intake 230/exhaust 230. Lobe lift .3200 at 106 intake centerline.
      Stout great sounding cam but might either be a lil worn out or need a lili different setup to get it a few points lower on the ET. Im not sure the cam fit the setup. Any of you professional engine builders should give me a tip or two on a cam that would fit my setup. Would be much appreciated. : )
      Patriot mid legnth ceramic coated headers, into 2.5 exhaust with 40 series flowmasters.
      MSD 6A ignition with MSD billet aluminum distributor with MSD blaster 2 coil. With MSD 9 mm wires.
      Pete jackson insainly noisy gear drive
      Offenhauser Single plane, medium high rise intake with holley 750 double pump on top. With a holley blue electric fuel pump(set at 8psi) fed from a 20 gal aluminum fuel cell.
      8 quart Canton racing oil pan with moroso deep sump oil pump.
      Stock crank.
      TRANS
      Th350 with stage blue racing clutches and a stage three shift kit with titanium main gears(i believe thats what they said, i just told them to build it stout as *&%$) haha. Able to hold over 600 horse. Bran new built by deans automotive. Shifted with a B & M megashifter.
      REAR END
      Chevy 8.5 ten bolt.
      Rear Discs, with new calipers, rotors and pads.
      3.73 richmond gears with new posi clutches.
      New T&T axels (new company from north idaho) Very stout and
      good axels from what i hear and great quality as well as good price.
      Custom ladder bar setup with customized floor boards(Driveshaft loop installed)
      ONLY 2200 Miles on engine and Trans as it sits in car.
      No miles on new suspension
      HERE IS A OLD PIC WITH BASE/CLEAR ON ENGINE COMPARTMENT, BELIEVE IT OR NOT THE ENGINE IS REALLY DIRTY IN THIS PIC.
      http://viewmorepics.myspace.com/inde...eID=1773652504
      Metro Detroit
      You need to post under Project Updates. Ask for a moderator to re-list for you.
      R.P.
      May 2002
      Northern California
      i can't see the pictures....can you upload to the gallery section?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Jun 2006
      If a moderator wants to move it then good deal.
      And i can try to upload the pics to the gallery section. Dunno if i can do it but i will give it a shot.
      Rennskii
      Beautiful car. Wish I was that far along on mine. Are you going to shave the door handles, or are they going back on after paint?
      '72 Nova- 350 c.i./TH350, stock suspension
      '49 Chevy 3600 pickup
      '66 Lincoln Continental
      www.fquick.com/debo75
      Mar 2003
      Lafayette, In.
      welcome !
      In process!
      1972 C10
      Roadster Shop Fast Track chassis
      LS376/525
      Jun 2006
      I have contemplated shaving the door handles and the trunk lock. But im not sure if i will, depends on how fast spring comes.
      Trilogy i believe we have talked on Steves site. Thanks for the welcome.
      Rennskii
      South Ga..
      never knew those wheels looked sooo good...
      Jun 2005
      Wheels
      You nailed the fit and look , Good job !
