Results 1 to 10 of 10
Thread: Why did they do this????
01-18-2007 #1
- Mar 2003
- Petaluma, CA
- 412
The attached picture is a head from an Alpina A4 motor (1970s 2002 BMW) that a buddy of mine is putting together for a customer. This is a very rare motor, that for the time put out a lot of horspower, approx 175hp. I am wondering why they put the divits in the combustion chamber and cut concentric circles on the intake valves (they did both sides of the valves). Maybe for heat dissapation? Anyone have any ideas?
-Jeremie
oh the motor is mechanical FI and NA
01-18-2007 #2I am not sure, but I would imagine it is supposed to act like a golfball and deliver improved airflow.
From http://www.hhp.ufl.edu/faculty/pbird...LE/DIMPLES.HTM
"The secret of dimples: The golf ball gets tremendous back spin from a drive shot, spinning as fast as eight thousand revolutions per minute. As the ball spins, the dimpled surface traps a layer of air that rotates with the ball, like a small whirlwind around the ball's surface.
Since the ball is traveling forward, the layer of air spinning on the top of the ball is moving "with the wind." And the layer of trapped air along the bottom of ball is moving "against the wind", so it is slowed by this wind resistance. As a result, air pressure builds up at the bottom of the ball, and the ball rises, much like an airplane wing.
The importance of the turbulence caused by the dimples is quite surprising. Without dimples, the ball would travel only about three-fourths as far. But there is a down side to dimpling--the ball has a greater tendency to hook or slice. "
01-18-2007 #3
