    Results 1 to 8 of 8
      Aug 2006
      where can I get compreesor clutch for this setup??
      Hello guys..
      The March Serpentine System had been installed on my car before I bought it. It was installed not too long ago. Yet, the freaking compressor clutch is slipping, and I think it is time to change it...
      I have checked Serpentine System Website on the internet, and I could not find it.
      I need to order one, but I don't know where to order it from..I have done some search on the their Website, but could not find one..I don't know if the pully with clutch are sold separately or I have to get the whole compressor.
      Please need your support guys. Some of you might have run into the same problem..
      Aug 2006
      fort myers florida
      check in JEGS i have seen them in serp. belt in chrome or polished
      Aug 2006
      Quote Originally Posted by wayne70
      Thanks for the info wayne70. I did find them in JEGS., I guess I need to check the type of the compressor I have in my car. I don't know if it is sanden 508 or something else.
      Here is what I found...
      thanks
      Northwestern NJ
      Does that compressor use chassis ground or a separate ground wire? If it uses the chassis, try adding a ground wire to it. Sometimes you get a poor ground on the chassis grounded compressors and it makes it seem like the clutch is goin bad.
      Tommy
      Tommy Souren
      "The older I get, the faster I was."
      Grandma's 20k mile '80 Malibu Classic, in-progress factory style LS6 454, Legend LGT 700 5 speed, 9" 3.70 posi, Global West suspension, 12"/11" discs.
      Aug 2006
      Quote Originally Posted by LS6 Tommy
      Tommy
      To be honest with you, I don't know, but I will check. Say it has a chassis ground, how can I add a ground wire to it?
      Thanks Tommy
      Northwestern NJ
      Just crimp ring terminals to a 10 ga piece of wire. Use terminals that are big enough to go under one of the compressor bolts on one end and small enough to fit under a firewall or fender screw on the other. Make sure where the terminals are there's no paint or coatings, just bare metal. You can even hook it directly to the "-" terminal of the battery.
      Tommy
      Tommy Souren
      England
      I would check that the comp has not seized, as i found mine had remove belt and try and turn it.
      Northwestern NJ
      Quote Originally Posted by paul67
      Belt removal isn't needed. The pulley freewheels except when the clutch is engaged. With the engine and keys off, you should be able to turn the compressor by hand from the clutch. It isn't real easy, but it should turn.
      Tommy
      Tommy Souren
