Thread: Break light help!
01-11-2007 #1
New to Pro-Touring
- Jan 2007
- 54
Break light help!
Ok, I had my breaklights working just fine. All the lights in the rear were working. (blinkers, Taillights) I changed out my turn signal cam in the steering colum and blew a fuse in the process. Ever since then I blow the same fuse very easily. I also have no break lights what so ever. My turn signals and tail lights work great.
WHAT DID I DO?
01-11-2007 #2Sounds llike you scraped the insulation off the wires when you pulled the harness thru the column, just a thought. Wire shorting out inside the column.
01-12-2007 #3
New to Pro-Touring
- Jan 2007
- 54
Thanks for the help. I found the problem. For those experiencing the same check the back of your turn signal cam. The brass fittings on the bottom were not springing back out thus not making contact with the bottom plate. Yes all the rear lights run through your turn signal cam. Hope this helps.
01-15-2007 #4I once had an intermittent short that took out my tail lights. I would sit in the car and have the short, get out and it would disappear. It ended up being the grommet going into the license plate light was cracked and it would short out when it felt like it.
Matt
