    Results 1 to 20 of 30
      Virginia
      The H.P. is probably around 425 at the flywheel. This car is VERY quick on the street. This motor went 12.20's in a 70 Elcamino with 3:31 gear on street tires. I just put a 6600 rpm chip in the MSD box and she pulls hard up to that rpm.
      I also thought that I would have to shift out of 1st real soon but it is nothing like I thought. Its easy pulling off from a light and the clutch is very smooth. I love it!
      On the highway at 75 mph it is turning around 2300-2400 rpms. (I think I have that right) I may have to double check that.
      gainesville ga
      The general rule of thumb is to keep your first/final gear ratio between 10 and 11:1. If you go too deep one way, youll end up having to slip the clutch a little more and the other way... first gear becomes too short and almost usless. So, anything that fall in between 10 and 11:1 is considered good.
      I would have to run atleast a 4.56 with my m21 to hit that.
      so i am going to asume my rule of thumb is not so high
      Shaun McCarthy
      68 camaro
