      Scottsdale AZ
      Do these timing #s look scorrect?
      I have a 450hp 383 with an HEI and a Holley 750.
      I initially set my timing to 35 @ 2500 RPM (vacume disconnected of course). Initial set at 10.
      The car does not have a nice crisp throttle reponse like it does if I increase the timing.
      I think initial is at 10.
      I also do not have the vacume advance connected.
      Here is what I am thinking:
      15 initial
      10 vacume
      10-13 mechanical
      Does that sound about right.
      Scottsdale AZ
      I am lookiging for advise on a general set up for a nice 383.
      1. base degrees
      2. vacume dgrees
      3, mechanical degerees
      marietta ga
      you are on the right track just make sure your vac comes all in before 3000 with a total max of not over 38 for non vortech head engines
      Oct 2006
      Ottawa, Ontario, Canada
      You always want to run as much initial as you can get away with.....without hard starting etc... If you have a cam with a good size duration, it will like it more as well.
      15* initial w/ 35 total sounds good......you may need to get an adjustable vacuum advance though that allows you to tailor the amount of advance you get under vacuum. mr. Gasket i believe makes one. You might find a stock vacuum advance unit may provide too much & might cause pinging, etc..
      -Carm
      '69 Firebird Twin Turbo SBC 400" Blow-through
      9.80 @ 141 w/ 1.88 60-ft..... on 17's
      9.21 @ 153 w/ 1.45 60-ft..... on PUMP GAS
      8.60 @ 164 w/ 1.46 60-ft..... on RACE GAS
      Santa Barbara, Ca
      Quote Originally Posted by brickyard69
      15 initial
      10 vacume
      10-13 mechanical
      You do not want to take the vacuum advance into consideration when setting timing. If you have 15 initial and 13 mechanical, that is only 28 total under WOT. I'd say 35 degrees +- a couple degrees is where you want to be.
      Be careful when looking at only initial timing numbers. Use a dial-back timing light (or timing tape) to check your total advance at higher rpm. Stock HEI's don't hit max mechanical advance until 5000 rpm or more. Just make sure you are checking the timing at a rpm where it has stopped advancing. For example, if you have 35 degrees @ 2500 rpm (with stiff advance springs) you could have 40 or more at higher rpm's. Check it to be sure. I think most HEI's have 25 degrees or so of mechanical advance built in.
      I always like to run the most initial timing as possible, especially on cars with big cams. To really dial it in, you need something that has advance limiter bushings (like MSD's distrubutors). I limited the total mechanical advance to 18 degrees, and then set my initial to 17 (for a total of 35). I also like to have all my advance in by 2200-2500 rpm. It will run better like this, assuming you don't gave problems with detonation with the aggressive advance curve.
      I wouldn't worry about what the vacuum advance is doing. It is only active during low-load cruising, and doesn't effect timing during acceleration.
      Hope this helps, let me know if I can clear anything up for you.
      Andy
