Results 1 to 12 of 12
Thread: crate motor, crank turning
01-02-2007 #1
hi i'm very newbie but i was wondering if turning the crank by hand will effect the way i start up my new engine.
i'm installing my torque converter and i need to turn the flexplate in order to torque the bolts down correctly. do i need to turn it back to its original position? this must be a real ignorant question - sorry.
it also has h.e.i. and was also wondering how i can tell where to start my wires from. i know the firing order and rotation but i'm not sure where i should start. thanks!
(385 fastburn crate engine to my th350)
1967 Chevrolet Camaro 350/350
1962 Chevrolet Chevy II 400 194/PG
01-02-2007 #2If the distributor is already in, and if its locked down you'll just need to bring the motor to TDC on the compression stroke for #1, take your cap off & see where the rotor is pointing.....that will be your starting point, then follow along with the firing order
Also you wont need to turn the motor back to its orignial position after tightening up the converter bolts.
1-8-4-3-6-5-7-2
-Carm'69 Firebird Twin Turbo SBC 400" Blow-through
9.80 @ 141 w/ 1.88 60-ft..... on 17's
9.21 @ 153 w/ 1.45 60-ft..... on PUMP GAS
8.60 @ 164 w/ 1.46 60-ft..... on RACE GAS
01-02-2007 #3
