    Results 1 to 3 of 3
      NY
      Air Ride Questions
      Not looking for an; "If it works debate".
      How accurate is preset height. What I mean is if you set a determined height how close is this height kept? Any change after use? I know there are a couple different ways to set this so I guess please list what you are using if you have any experience.
      Is there a sag to the bags? I know it can be compensated for with addtl pressure??
      I appreciate the help.
      Jun 2005
      Greenwood, SC
      kept as in inflated to the preset, deflated, and reinflated to the preset, or kept as in maintained after inflation?
      jasper IN
      Quote Originally Posted by BRIAN
      Preset ride height can be very accurate, depending on the system, we offer 2 systems, the ridepro e2 kit use sending units to measure air pressure, this system works good, but if you are looking for something that is a true leveling kit use our Levelpro system its uses the sending units to measure pressure and a sensor at each wheel to achieve a perfect height every time, even if you add a few people and luggage.
      Jason Brady
      www.ridetech.com 812-482-2932
      The Guy who invented the first wheel was an idiot. The guy who invented the other three was a genius.
