      cant set installed height
      Was told to set my installed height at 1.800 But The closest I can get is 1.745.
      This is with trickflow heads and spring cups already installed. Obviously adding shims would make it worse.
      Why would I need to have a set of heads machined to get the correct height when supposedly they are set up for cups already??
      *****IN ADDITION***
      These valves seem to have very large margines. Would a good valve job give me the added height I need? I wouldnt doubt if the previous owner/builder installed the valves with out doing any sort of grind. A basic 45* is on them now.
      Just to clarify this is on a hyd roller cam and howards springs 98213
      120#@ 1.800 375#@ 1.250
      @ 1.75 they are 145#
      Montgomery, IL
      Crane makes valve locks that will give you an extra .050 of installed height. Make sure you get the machined ones as they offer two types. Here is a link: http://www.cranecams.com/?show=brows...Number=99095-1
      71 Formula, 455 SD/KRE D-Ports, Crower solid cam, TKO 600, 3:73 Eaton posi. 17" ARE 200s, , 1LE brakes, Koni, Rancho adjustable bars, Hotchkis springs
