12-28-2006 #1
New to Pro-Touring
- Dec 2006
- 3
68 GTO front suspension questions
I'm new so please forgive me if this is the wrong place for these questions. I've lowered the front end of my 68 GTO about 3" by cutting the front springs and the rear by installing a set of 2" lowering springs. After cutting the front springs I took the car in for an alignment and was told that the geometry was so far off that they couldn't do anything for me except to set the toe (which they did). The car is very "jumpy" on any uneven pavement especially at highway speeds. I'm told that this may be a "bump steer" issue and that there is a Baer product out there that would resolve this by moving the tie rod end in to better alignment. I'd be thrilled if that were all I needed to do. I just put a drum to disk conversion kit on the car last year and opted to stick with the stock type disk brake spindles. It looks like drop spindles and lowering springs are an option also, but I don't want to redo that work if it will lead to similar trouble or if there is another way (Baer kit) that will resolve the issue.
I'm also not really going for fantastic cornering ability, just more of the aesthetics of the lowered look and respectable road worthiness. Any thoughts or experiences would be really appreciated.
12-30-2006 #2
New to Pro-Touring
- Dec 2006
- 3
I think I'm going to try the Baer Tracker kit and see if that takes care of the bump steer.
12-30-2006 #3DO NOT PUT DROP SPINDLES!!!! This will worsen the bump steer issue you are having. Call Baer and see what they can do for you. You may want to consult with a suspension expert to see what the problem really is but it does sound like a Bump steer issue.
***Under Construction***
Build Update Link:
12-30-2006 #4
