      Feb 2006
      Columbus, GA
      Anyone Running 79 TA Rear Disc on a 2nd Gen Camaro?
      If so, would you please help me figure out the parking brake cable requirement? I've got the rear discs hooked up and working fine...I've installled 79 TA rear parking brake cables coming off of the calipers...is there a cable (like the Camaro) that runs across the two rear cables? If so, where do I get one? Thanks...in advance.
      Tom
      1970 SS Camaro, 502 RamJet, TKO600 Tremec, 3.91 Moser 12 bolt/Detroit Tru-Trac, C5/Z06 Brakes.
      Jun 2006
      Katy,TX
      They should clip right in to the cable for the drum rear parking brake. They just take a different length cables from the calipers to the connector vs the drum cables.
      Feb 2006
      Columbus, GA
      Thanks, I'll try... Guess I should've kept the old stuff when I tore the car apart!
      Jun 2006
      Katy,TX
      Cable from the pedal has a 7/16 nut(I think) that pulls on a slightly U shaped piece the individual cables slide into, whether drum or 4WD. More on the drivers side. Passenger side slides on exhaust pipe some to get there.
