      To those with the TVS
      I have a '70 nova. Im looking at this kit, just wanted to get opinions of those who have it - worth it etc?
      Maybe post some picture of some Novas with it installed
      thanks
      Sep 2002
      San Jose, CA
      Great kit for a street car
      Just call me Brett
      Aug 2006
      Hampton Roads, VA
      The TVS is about the best bang for your buck out there! If your car is mostly a street machine that may see occasional track use, I say go for it! Make sure to include wide, sticky tires and big brakes too though.
      1980 Pontiac Trans Am, Chevy Big Block 468, TKO 600 Trans, Hotchkis TVS, Bilsteins, Eaton/Motive 3:73's, 18" Coddington Junkyard Dogs, Nitto NT555 rubber, Autometers http://www.fquick.com/Bandit
      http://www.cardomain.com/ride/2458763
      Delaware, OH
      '70 Nova here as well (click my signature pic for some pics). Originally I was impressed with the handling improvements of the TVS over stock, but was less than thrilled with the ride quality. In the end the ride quality was due to my choice of shocks, so if you go TVS I suggest getting the Hotchkis-valved Bilsteins as well. Overall I'm pleased with the kit, but still had to trim the front coils to get the stance I preferred.
      Aug 2006
      Hampton Roads, VA
      Quote Originally Posted by dhardison
      Good point, I have the Hotchkis Bilsteins and the ride quality is great!
      thanks for the input guys
      Dan that is a beautiful car
      I do have another question for you - does you car bottom out any over bumps? i have a 454 in mine and a pretty stock suspension and i tend to bottom out over bigger dips, pot holes etc.
      Delaware, OH
      Quote Originally Posted by 70nova
      Thanks! I only had bottoming issues on the front after installing the TVS. Originally I cut a full coil out of the Hotchkis coils, the stance was spot-on, but it bottomed pretty bad. I only had ~1/2" clearance between the front a-arm bump stops. I've since replaced the coils again and this time only cut 1/2 coil. The stance isn't quite as good as before, but it drives much better.
      With the full coil cut ground clearance between my old 454s Hooker headers was pretty tight at only 2.5"-3". I dented 3 tubes on the newly coated headers on the '06 Power Tour. The 572s headers are tighter to the floor boards so it's not as bad. Never had any issues with bottoming on the rear (no pun intended).
