Thread: Electric Brakes
- Nov 2005
- 16
Electric Brakes
I have a 1946 Chevy Truck with hydraulic booster brakes. The problem is, room in the truck is very tight and when the steering column was added, the brake pedal had to be on the left side of the column. You have to use both feet to drive the truck. The problem is the pedal is mounted so high and with the cramped interior, you have to raise your leg pretty high to use the pedal. Not a good thing if you get in a bind in traffic. If I could rest the ball of my foot on the floor it would not be as bad.
I'm curious to know if anyone has used the new electric brakes I have read about. Any problems, good bad, indifferent?
Dan Mascheck
Wharton, TX
