      Automatic to Manual Conversion in '77 Firebird
      Hey all, I have made my decision and I want to go manual with my 1977 Firebird Formula. I am planning on rebuilding the original 400 Pontiac engine and running it in the car so I was thinking this would raise a problem as Chevy and BOP trannys have different patterns right? May be a stupid question but I have to ask being a noobie. Also how hard is the conversion itself and is there a site or something that tells all the parts needed? I did a search but still coulden't find them all for sure. Also what is a good choice for a tranny? TKO500 or 600? Any other suggestions? Any input would be great in helping me decide. Thanks!
      Dunwoody, GA
      The auto transmissions are different, but the manuals are not. The bell housing has a different pattern though so you will need a BOP bell housing. After that it is not very different. You can try Classic Chevy Five speed and Kesler and see if they have a convertion kit to upgrade to a Tremec. You may need to source a stock xmember or possibly someone already has an aftermarket xmember that will hold the Tremec. You will need to get new pedals so that you will have the correct brake and clutch pedals. The car would have had a manual clutch. If you choose to stay that way the hole that the rod should have gone through may just have a grommet in it or it's marked and just not drilled. This really won't be hard so long as you do your research and have the correct parts on hand before you start just randomly buying up parts. Remember, the firebird and the camaro are basically the same car and many of the major parts interchange functionally eventhough they may not be correct.
      Trey
      ~ Jon Hammond
      Thanks for the info on this so far, it really helps. Another thing I was wondering on is what is all the talk on hydraulic and cable clutches or stock linkages? I have been trying to soak up all the knowledge on here for the past week but its hard to do as there is so much! Thanks again!
      Hmmm... After gathering more information it seems that the mechanical is the way to go, so can I just buy up stock linkage parts or what? This research stuff is killing me I am ready for a teardown! lol
      Dunwoody, GA
      Well there is a company called WFO out of Texas. Austin I think. That has rod end clutch linkage for these cars. I belive you would still need the part called a Zbar, but the rods I would say get from him since you need new ones anyway.
      The bellhousing for that engine and what would have come out of that car is designed for a manual clutch. If you wanted hydrualic it could be done, but you would have to mount the slave somehow or go with a slave/throwout bearing setup that the LS1 Fbodies had. Manual will be easier.
      Try this website for not only parts and what's availible, but I am sure you may find someone else's wirte up and what they went through to convert to a manual transmission. They have a forum section as well. This is just the main page. www.transamcountry.com
      EDIT:
      Ok I couldn't find the WFO website, but WFO is a sponsor for transamcountry. You can find the info about the parts and I am sure his website on that board.
      Trey
      ~ Jon Hammond
      Pensacola, FL
      I am probably going to sell my TKO500 as I have a line on an LS1/6speed wreck. It has very low miles and comes with cross member for 69 camaro, which I bet you could easily make work. Also included is pro billet 5.0 shifter, speedo cable, poly trans mount, and drive shaft, which is also for 69 camaro but may work out to be the right length. Just PM me if you are interested or email directly at [email protected]. Scott
      Jun 2006
      Katy,TX
      I converted a 79 Camaro from a auto to a stick. You will need pedals(brake and clutch) and the different bolt that holds them in the dash. Linkage. Hole saw for cutting hole in the firewall for linkage. Z bar. Chassis Z bar bracket and 3 self tapping bolts for the frame(that's the hardest thing to get to to tap them straight). Easier without the fenderwell, and fender.Holes are generally already there. I used a tap instead of self tapping bolts like the factory did. The rubber boot for the linkage is real hard to get the two holes drilled with the brake booster present.
      The crossmember for the TH 350 fits the ST-10 or Muncie of you are going 4 speed.
      One potential problem some Pontiac cranks are not machined for a pilot bushing/bearing. So that could be a problem for you. While it's apart check it and machine for one.
      Aug 2006
      Hampton Roads, VA
      The TKO 600 is the best and strongest street tranny out there today, you are right to be looking in that direction. I have almost 1,000 miles on mine and I am very happy with it!
      Using the "search" function on this site will bring up just about every situation you could encounter during the install, as well as where to buy all the parts. My recommendation is to pick a reputable company like Keisler or Classic Chevy 5-speed and get all of the parts for your swap through them--it will greatly simplify the job.
      I posted detailed instructions for the swap in the post linked below:
      https://www.pro-touring.com/forum/sh...light=detailed
      This is based off my experience and of course will vary slightly for your application, but the basic concepts apply. Used together with your other info it could be of help to you. Good luck, keep us updated! Don't be afraid to PM me for other questions you might have--I'm here to help!
      1980 Pontiac Trans Am, Chevy Big Block 468, TKO 600 Trans, Hotchkis TVS, Bilsteins, Eaton/Motive 3:73's, 18" Coddington Junkyard Dogs, Nitto NT555 rubber, Autometers http://www.fquick.com/Bandit
      http://www.cardomain.com/ride/2458763
