      Central Texas
      65 Chevelle Wheel Choice
      Need some help. I have come down to needing to purchase wheels for my car and after looking at all my options I keep going back to Torq Thrust II wheel. I have made several suspension modifications and had a set of Torq Thrust off of another car that I put on my Chevelle just to get a look see before I purchase wheels. Well I ran into a snag, I found out that a Torq Thurst will not fit C5 Wilwood front brakes.
      So this is where I need some help, I have looked until my brain is about to bust and can't decide on anything else. It is so hard to tell unless the wheel in on the car.
      Any thoughts would be greatly appreciated. Below is few thinks I have done that might help in picking a wheel. Tks, -Kenneth
      I have lowered the car 2" in front and 1" in the rear. I still may lower it more if need be. I had plans to run a 17X7 in the front and a 18X8 in the rear. Wilwood disc brakes front and rear. Narrowed rear-end 1" on both side to gain a little more positive off set.
      This is the most recent picture I have, I have a picture with the front end on it, but it was before I started this project, I will just have to find it. Thanks again...
      Feb 2006
      SoCal
      Ya might want to consider these:
      PM me if your interested!
      John
      ***Under Construction***
      Build Update Link:
      Central Texas
      Quote Originally Posted by novanutcase
      John
      John,
      I saw this wheel and thought I would have the same problem because it is similar style as the TTII. American racing told me the TTII can not be custom made. I need more clearance between the spokes and caliber. Can this wheel be custom built to accommodate for this?
      Nov 2002
      Georgetown,TX
      Quote Originally Posted by KMD
      Narrowing the rear will require a wheel with less positive offset or even one with zero. 5" backspace is about optimum for an 18x8 wheel on a 64-65 w/stock rear. If you narrow the rear 1" per side,that changes the needed BS to 4". Zero offset on a 8" wheel is 4.5" so 4" would be a negative offset.
