Thread: LS1 T56 Clutch question
12-23-2006 #1
Hello,
This might be a redundant question but I did some searching and couldn't find anything on it.
I currently have a BBC 427 in my 67 Camaro with a ls1 T56 and the ATS install kit it also has a 11" 168 tooth flywheel. I'm looking to buy a clutch for it but when I look I'm not sure is I need one that is specific to the LS1 tranny or if I can just buy a 11" 1 1/8x26 spline pressure plate and clutch disk?
I guess all I'm asking is if there is a difference between the LS1 t56 specific clutches and the regular GM 11" 1 1/8x26 spine clutches other that a part number and price.
Thank you for your help.
Ryan
12-23-2006 #2
Starting The Transformation
- Oct 2005
- Lima, Ohio
- 216
The regular 26 spline will work just fine. The ls1 is a bolt in. Its the lt1 that requires the special type of clutch. I go with zoom/perfection. I hear the centerforce II and DF is a good unit but more pricey.
David
12-25-2006 #3Cool. Thank your for your help. I appreciate it very much.
Ryan
