Thread: center support bearing
12-23-2006 #1
does anyone have any idea where i could get my hands on a billet aluminum center support bearing for my 64 impala g-machine ?
12-23-2006 #2
- Sep 2004
- Chicago - western burbs
- 681
12-23-2006 #3thanks pal ur a life saver.
12-23-2006 #4i tore up 2 center supports in 2 months i put in the IED piece along with a slip yoke drive shaft and haven't had a problem since.
12-24-2006 #5a slip yoke d/s ... good idea. how much did you lower your car?
12-24-2006 #6about 5 inches, the front cross member sits about 2 inches from the ground, it sits a little lower now than pics(those are a year old) everything has settled in now.
you should consider a slip yoke, if you lower it anything more than 2.5 inches, your drivshaft will start binding up on you giving you problems and that IED center support is a solid billet piece instead of being a piece of stamped steel.
