    Results 1 to 19 of 19
      Body dropping a 68 Camaro
      A buddy of mine is thinking about attempting a body drop on a 68 Camaro. He does not have the internet hence why I am posting for him. We both know what is involved in doing a framed vehicle but since these cars a unibody there are going to be differences. I wanted to start getting suggestions and ideas from the people here.
      Some of the reasons for doing such on his car are:
      Keeping ground clearence under the oil pan, for exhaust scraping, under carage draging and lowering the center of gravity.
      He wants a real low stance and is concerned about the above.
      First thing that comes to mind is the way the front subframe mounts. Obviously that would need to be reworked. We think moving the lower legs on the subframe up to where the rocker is, we could then reinforce them with some plate steel to the rocker still allowing us to bolt in the subframe. Rework some sheetmetal in the firewall area where the frame curves up towards the front suspension.
      The inner fenderwells are coming out any way and those will get remade completely.
      I'm assuming something will need to be done about the radiator support as moving the subframe up on the body would cause an issue there.
      The rear of the car we were planning a back half any way so that is going to be completly different so no sense in really going over it yet.
      What other areas on the front end would have to be tweaked to make such a thing work?
      Anyone see someone channel a subframe set up?
      Thanks in advance.
