      Flush mount valve stems?
      Anyone have any actual experience with a set of the flush mount valve stems?
      Im upgrading to C6Z brakes this winter, and I know my standard valve stem is gonna hit. Wondering if anyone has run into any problems or anything with them.
      Going on my 18" bonspeed wheels on my s-10, and truck is basically my warmer weather ride. So it'll see plenty of street duty.
      Chicago
      i have pic of the stems from Weld in my gallery somewhere.
      look for them early in the thread where i was checking clearence with the calipers.
      marty-mj
      This the picture your talking about?
      Approx how much do they stick out from the rim?
      Chicago
      i would say they are about 3/16 of an inch up.
      marty-mj
      Thanks man, I appreciate your help. Hopefully that works out for me.
      Connecticut
      not happy
      i was not happy at all with the flush mount ones that i had on my 68 camaro. i needed a little flat head screw driver to get them off and several times the rubber part that was under the wheel would break causing the tire to go flat in a couple of seconds. they were really annoying. just my opinion
      Central Florida
      I used flush mount valve stems for about a day. I also had the O-Rings go bad on two of my wheels = 2 flat tires. I am now using a very low profile-- all metal valve stem (no O-Rings).
      Morehead City, NC
      I have Smoothies on my front wheels on the Tempest. Pain in the butt to check air, but they do clear the caliper. Use em as a last resort.
      Mike
